Results 1 to 13 of 13
Thread: Cheap Tires 25x12x9 ?
    Jun 2018
    Holland Mi
    93
    Any suggestions? I got some a while back for like $60.00 ea but I cant seem to find them back! Any ideas ?
    Scootertrash's Avatar
    In the sticks
    4,638
    Holland huh? My wife is from Holland.
    depending on how long a "while back" you got the tires, they may not even be available any more.
    Here:
    https://lmgtfy.com/?q=25x12x9+ATV+tires
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    They don't get much cheaper than this. https://www.ebay.com/itm/2-PAIR-25x1...nd!13160!US!-1
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    Deestone tires are decently cheap. i paid about 120 for a pair of the D292 in the 25x12x9 size. i have also run the d930s before (they are about $15 more). cant beat them for the price. I get them on ebay, they are cheapest there.
    Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, Trx250X,ALT185
    Arkansas
    2,447
    How true to size are those Deestone tires?
    There are tires that cost less because they aren't actually the listed size when installed and inflated to ATC pressures (~2-2.5psi)
    Same thing happens a lot with bicycle tires. True tire sizes can be a shady mess. I've used several current brands of 25x12x9 ATV tires, and I don't think any of them have been the same size. I've even had the same brand, same size pair of tires and had to run one at considerably higher pressure in one, just to get the same diameter.
    Apr 2012
    USA
    4,133
    I got a set of 3 tires for my 200es from TSC, it was an old item/model and they haven't sold it for years. I asked the manager about them and he claimed he sold them to me at a loss. The rear two tires were around $30 each while the front knobby tire was $35. This was around 10 years ago, tires are still holding up great but clearly you'd have to find a store with an old set of tires that the manager just wants to recover the self space on.
    In the photo with several machines, it's the one on the right, the rest are 250es's and the near one on the left is my 250sx. Those rear tires don't look special at all, but they perform quite well for the tread being so close together. I've been through a lot of mud with them for what they are (2nd gear high range, or 3rd gear low range if I remember right at pretty high rpm).
    Apr 2019
    South Dakota
    255
    They tend to run a bit short. It would be comparable to haw Kenda Scorpions run short. So keep that in mind. I have yet to find a 25x12x9 tire that is comparable to the factory Ohstus. I dont know if they are always short or if the factory Ohtsus are just really tall.
    Apr 2012
    USA
    4,133
    Yea for the most part atv tires generally run on the small size. The 28in highlifter outlaws big advertising point was that they were a true 28in tall tire.
    Apr 2014
    Edmond, KS
    2,591
    I have a friend who had some 25" tires on his 250ES that I swore were 27". Those things looked HUGE for only 25".Click image for larger version.
ID:	261070The closer one is the one that I'm talking about. The ES's are his. the SX is mine.
    Arkansas
    2,447
    I have a friend who had some 25" tires on his 250ES that I swore were 27". Those things looked HUGE for only 25."
    INNOVA MUD GEAR
    Attachment 261071
    Not cheap though. The newer version has some extra side knobs.
    Attachment 261072
    The ones on your friend's BR are a bit worn down, but that's probably makes them better for a trike. They are still available in 25x12x9.
    Apr 2014
    Edmond, KS
    2,591
    Yep. That's them. I just couldn't remember the brand and name. While not real cheap, I think he said that he got a deal on them at about $80 each. They are probably worn down since he and his girlfriend did a lot of dirt road cruising with the one that has them.
    Jun 2018
    Holland Mi
    93
    Thanks fellas I appreciate it
    Nov 2013
    Oxford CT, New Haven County
    984
    tractor supply? they may have something.
