Results 1 to 7 of 7
Thread: 1985 250sx honda just joined today been reading for years
    NDD is offline New to the board Arm chair racerNew to the board
    Nov 2019
    Allegan MI
    11
    just put new shoes on my trike. Still barely any rear brakes. I have to press the pedal very far. The adjustment wing nut cranked all the way on. I have read that several member have moved the brake arm two or three notches on brake cam to fix this I looked up new cables (mine are original) and looked up new drum (mine doesn't look bad but i didn't measure it) but only could find used drums. Has any one else have have had success or any ideas on to improve rear brake action. Excuse my fat finger typing. I just got of the three wheeler for a ride and its cold with no gloves! forgiveone picture It loaded upside down!! Peace
ID:	260536   Click image for larger version.
    Apr 2014
    Edmond, KS
    2,581
    Welcome. I'm glad that you finally joined. Nice looking SX.
    djm0242's Avatar
    djm0242 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2011
    Rockwall TX
    297
    I wouldn’t adjust the brake arm. They can be tricky. Just a guess here but the cable is probably stretched. I’d just replace it. Last I looked the short foot cable was like $17-20 on eBay? Good luck ��
    79 110
    83 185S
    84 250R
    3x85 Big Reds
    85 200X
    85 ATC 70
    85 Tri-Zinger
    86 200x
    86 TRX 125
    87 TRX 250
    89 TRX 300
    98 TRX 450S
    03 TRX 350
    5 Foreman 500 4x4's
    You can never have enough! ATC250ES is still the best!
    6,757
    Did you buy OEM Honda shoes ?
    Most of the aftermarket / china shoes are crap . They give you very spongy non adjustable braking
    Nov 2019
    Florida
    1,045
    "1985 250sx honda just joined today been reading for years"
    Hey me too.
    MrC.
    Nov 2019
    Allegan MI
    11
    I did end up adjusting brake arm a couple of notches. The brakes work well now. I finally have working front and rear brakes!!YAY
    Apr 2012
    USA
    4,133
    There's a punch hole on the brake shaft, and the brake arm is missing a spine or has another mark. Normally they should line up else your drum or brakes are out of spec.
    Here's the specs for the drum and pads.
