Thread: Where can I find the engine serial number?
    Oct 2019
    Central valley California
    9
    On the neck of the trike, it says 185s but the year is rubbed off.
    May 2009
    S.E. Michigan
    1,251
    The VIN should be stamped on the side of the neck (stamped in metal, not the foil sticker).
    10th digit (a letter) in the VIN is the year:
    1980: A
    1981: B
    1982: C
    etc...
    1987: H
    The engine serial number is usually stamped on the side of the crankcase where the shifter shaft is. Look for a rectangular flat area where the shifter goes into the crankcase, and wipe away any dirt and grime. You should see the engine code there.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Oct 2019
    9
    Thank you wonderboy.
    Apr 2012
    USA
    4,133
    Yep, engine serial is under the sprocket area. Frame VIN number could be before the 17 digit standard, if so it's a 1980 and starts with TB01. The engine serial all starts with TB01E for the 185/185S engines. The atc200 and 200s engines start with TB05E. The ending part of the serial identifies make/model/year, first part is a generic model code for the engine (200m, 200es, 200e, 200x etc uses the same code).
    FYI, it's possible your engine could have been swapped, there's a few models that interchange, so never hurts to check frame VIN & engine serial to know what you have.
    Vin/Engine Serial Decoder: http://atvmanual.com/honda/interacti...er-atv-and-atc
    Manual VIN/Engine lookup table: http://atvmanual.com/honda/frame-vin...serial-numbers
    Oct 2019
    9
    Ok so my 2 frames say,
    1. TBO1 2014601
    2.JH3TB0100CC272694
    I need to get out the pressure washer again to get the engine number.
    Engine number coming soon.
    Apr 2012
    USA
    4,133
    TB01 2014601 = VIN decoded to: 1980 ATC185
    JH3TB0100CC272694 = VIN decoded to: 1982 ATC185S
