Ok, I celebrated too soon. Changed nothing last night, this afternoon put a new full line in and tried to start, NO SPARK!
The kill switch is stock. I get a circuit from the black wire when the switch is to OFF, breaks the circuit when switched to RUN, at the black wire on the CDI Connector. The switch will not swing left, it only goes center and right, must be old.
CDI is marked CF433.
Here are my OHM readings....
xxxxxxxx
Check exciter coil ohms (you could test voltage but you need a peak voltage tester). Black -> Green = 150-400ohms
262 OHMS
check pickup coil/pulse generator. blue/yellow -> green = 20-30 ohms
35.5 OHMS
check ignition coil primary coil. black/yellow -> green = 0.16-4 ohms
10 OHMS (reading a tiny bit higher at the CDI connector is fine since it's extra wire length not accounted for in the spec). Also if you have a cheap meter, it might not be able to get accurate readings at such a low ohms, pretty simple test is to touch the two test probes together, you should see 0.0 ohms or very close. The cheap meters I've tested read 4-30+ ohms
3 OHMS before cleaning up the tips/contacts.
check ignition coil secondary coil (at the coil for this one). coil ground/green wire to spark plug boot. Should read somewhere around 8-10k ohms (10,000 ohms) with the spark plug cap on the wire, or around 3-5k ohms with it off.
7.59K OHMS with Cap On
What say you Sir? Thinking that switch is shot, how do we take out of the equation for testing purposes? Also need a way to shut it off too!!
PS I would buy your switch if in-stock, let me know, glad to give you the business!
