Results 1 to 12 of 12
Thread: LED headlight battery
    Mar 2013
    Wausau, WI
    147
    Has anyone used a lithium ion battery pack to power an LED headlight? If so, what did you use?
    Jul 2013
    mo
    327
    Ive seen guys use drill battery packs
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    What trike is this for? Converting an ac voltage trike to dc voltage is not difficult. I've done it to both my 350x and 200x using a large capacitor and battery, respectively. I run the same LED light bar on both machines and like the setup.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Mar 2013
    Wausau, WI
    147
    Thanks guys, I bought this one. It's for my 84' R, I wanted to have a really bright headlight and I don't want to deal with the light being dimmer when the engine is at idle. I want a constant brightness all of the time.
    Apr 2012
    USA
    4,133
    Quote Originally Posted by dmfaulks85 View Post
    A battery + regulator would solve your problem if the high rev brightness is good enough for you. With an LED, you will still need to filter the power to DC via regulator, and a battery/cap to keep the voltage while at idle or you risk damaging the LED's from under voltage depending on their specs.
    I don't really follow the post that is up a few, basic math is the # of amps draw / ah rating of the battery. So say the LED light is 30w @ 12v = 2.5 amps, for 3 hours run time you need 7.5ah battery, or if you only need 1 hour per charge, then 2.5ah would be fine. You size the battery to the load. Lithium Ion are designed for quick or slow discharge, does not matter, charging them is similar. Lead Acid that the trikes use are short term high amp design, and like being charged slowly. Drill batteries almost all use Lithium Ion now, older ones used NiCa, which has a flaw of the memory effect, but is a deep cycle design like the Lithium Ion.
    Anyway, the above is kind of not needed since you're powering it off your machine's alternator, you will just need a small cheap battery and a regulator to make the system work well.
    Apr 2002
    s.w. michigan
    6,498
    Why don't you hook it up and try it, it is only drawing a fraction of the stock headlight bulb
    It may not dim at all at idle.
    Apr 2012
    USA
    4,133
    Quote Originally Posted by jeswinehart View Post
    From my understanding, lower load = higher voltage. Just for an example, if you unhook the headlight from a 250r, the tail light will blow due to too high of a voltage. With the LED light being 36w vs factory headlight being 60w, I don't know if the voltage will be too high or not at high rev. Most LED lights I have seen work from 10v-40v, sometimes they only go up to 24v though, and purely resister designed lights are designed for the 13.6v like a car would put out.
    I don't claim to be an expert on these, but I have burned out LED headlights before, don't use a battery charger to power them, they do not like it!
    Apr 2012
    USA
    4,133
    I see, the way I read it, it made it sound like you were taking lumans into account in the power usage instead of just the light output. I always viewed the lumans vs power usage as just how efficient the LED/Driver was, of course if more light is needed, more lumans is what is needed, and generally it sucks more power.
    I won't go into too many details, but I have 80% of the supplies to go off grid, so LED light is something I'll be using, but I'll be building the lights to my needs such as low light at night to save battery power and to be somewhat of a night light vs running 100%. A side effect is longer LED life, cooler operation, and higher efficiency of power used vs light output. Simply put, 3w led running at 1w is more efficient than a 1w given the same grade/manufacture of LED, aka the 3w @ 1w draw would give out more light.
    I must have missed the link when I read though the post, but wow is that little light expensive. 95% efficient driver is very good though, most are 80-90% last time I researched them.
    Mar 2013
    Wausau, WI
    147
    I think I'm going to hook it up to my drill battery and see how long it lasts. And if it doesn't last long enough for me I'll wire it into my wheeler.
    Apr 2012
    USA
    4,133
    If you can find a rating on the battery for ah (amp hours), we can estimate how long it will work. Just a quick example, 3ah @ 14v and the led light using 36w should last around 1 hour 10 mins.
    Jun 2009
    Leander TX
    2,217
    I run my LEDs off the stock lighting coil.
    You should use a regulator if your trike doesn't have one.
    Since the 3rrd gen R and the 350X have a voltage regulator, I just plugged the LEDs in.
    On the T3 and 70s I added a generic 2-wire regulator.
    They work great. They do flicker at low idle but they're never dim.
    If you want a battery - maybe try an RC car battery? They're cheap and small. You could carry a spare for a long ride. Charge them in the truck.
    Apr 2002
    s.w. michigan
    6,498
    I can vouch for Tecate needing some kind of voltage regulator.
    I burnt up a old school vintage 2 stroke tach when I wired in direct.
    Tecate mags produce about 7 volt at idle and jump to 18+ volts at 9k rpm.
