I'm looking for a little help to make sure I get things right for the requirements of making a regulator work for an 1983 ATC200, but should be the same or similar for other machines like the ATC185s.
Wire diagram: https://gyazo.com/627c1477c0b62940db176ef81cf1ccd0
Since I make harnesses, I'd like to make an "inline" regulator adapter for this machine. I have a customer that bought an LED headlight from me and they are trying to get it to work correctly on the 83 atc200. I suspect the best place for the inline regulator would be right at the AC Generator 3 wire plug. I understand the basics how the regulator works, but don't really know the difference between a 2, 3, 4, 5, 6 wire regulator, I suspect it depends how the AC power is generated and the output is always 2 wires, and some ground though the case of the regulator. I'd like to wire up one that grounds via the green wire if that is an option, and 2 wires come off the ac generator (yellow + green).
So what I'm trying to get at, is, is it possible to wire in a regulator inline at that 3 wire plug, or would it take a pretty major require to pull this off? Maybe the black wire is required too, not fully sure. I don't want to cause issues for the CDI either. I don't have a machine on hand to test anything on, so any help would be great.
I'm finding quite a few regulators intended for Chinese quads for pretty cheap, I know Chinese quality isn't the greatest, but it would be an option. Most I find are 4 wire, some are 5 wire.
Thanks for any help/comments!
, hopefully it will be useful to others as well.
