Well I was enjoying my BW200 that I have had for 2 weeks yesterday. When it started making aing noise from the top end. If you let off of the throttle and pull in the clutch it dies like you flipped the kill switch, but will power through it while running rough. It always starts right back up and would run fine for a few more minutes till it done it again. I have eliminated any shorts in the wiring. I am leaning towards a sticky valve, broken valve spring, or slightly bent valve since it will come out of it. I assume the
ing is the rocker hitting the valve. I tried some seafoam and marvel mystery oil to clean and free the valve. Nothing worked. Looks like i am going to have to tear the top end off to take a look.
