Thread: differences in 86 tecate and 86 kx250 engines?
    Jun 2002
    Mississippi
    2,552
    are they the same or are the different? porting? gearing? same power valves?
    thanks
    chris
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Jun 2003
    englishtown NJ
    2,676
    the top end has different porting, different powervavle setup(interchangeable), but basically the same, the same is true for the 84/85 kxt and 83/84 kx250.
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    For a little more pep on your 86 you can run the KX Carbon reeds and the thinner KX headgasket.
    Curtis.
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    JBKX is offline New to the board Arm chair racerNew to the board
    May 2003
    27
    IF I REMEMBER RIGHT, 4TH AND 5TH GEAR ARE DIFFERENT RATIOS. THE DRIVE GEAR ON THE BACK OF THE CLUTCH BASKET IS 1 TOOTH SMALLER AND CONVERSELY THE SPROCKET ON THE CRANK IS 1 TOOTH LARGER ON THE KX250 ALSO. I HAVE PUT A CYLINDER FROM A KX ON A TECATE AND COULDN'T TELL MUCH OF A DIFFERENCE.
    352
    If my memory is correct the cylinders were the same on the 86 KXT and KX. Now the 84/85 was a different story as the more agressive KX cylinder is the way to go.
    Curtis
    Oswego NY
    1,935
    JBKX is correct. I have a 86 kx250 trans, it runs a different 4th/5th. I have a 86 kx250 cluch basket w/ drive gear in my T3, it is a 1 tooth difference. I know HAGEN has the same setup for his T3. There is a different shiftshaft seal on the kx also. I know the ignitions will swap, the jugs will swap, the heads will swap, the side covers will swap, the kickstart gears will swap, powervalve stuff swaps........just keep in mind what stuff came off so that you get the rite seals for the rite covers, the rite basket for the rite drive gear, ect, ect....
    GOOD LUCK
    MIK6 / Mike
    New England Ride 4/13
