Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: lifan 200cc
    Feb 2009
    michigan
    2,387
    lifan 200cc
    well i pulled the trigger today and bought a lifan 200cc for my 185s.should be here in a week or so.keep you posted with pics when i start
    1985 ATC 250R
    . Team Red Trike
    Feb 2009
    Rome,NY
    1,046
    Sweeeeeeet!!! you will have the baddest 185s around. Keep us posted on how it works and if you are going to use the electric start or the kick conversion
    Feb 2009
    michigan
    2,387
    thanks
    will do, probably use the electric start,plenty of room for a battery.
    1985 ATC 250R
    . Team Red Trike
    2hundredx's Avatar
    2hundredx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    Missouri
    392
    just installed a lifan 250 on my 200x today. bolted right in. easy conversion. me and my buddy (redneck wheeler on the boards) put it in and we put all of the wiring in the air box and put a home made k&n filter on the carb. we intend to put the battery for the electric start in the air box also
    My first 3wheeler- http://i290.photobucket.com/albums/l...ite200x002.jpg
    Current 3wheeler- 1985 250R
    "Your four wheeler must be fast 'cause you were haulin ass when I passed you on three wheels"
    Feb 2009
    michigan
    2,387
    put it in lifan 200
    well put the lifan 200cc in my 185s this weekend.hit a couple bumps but all is good.i am going to come back with pics all the way through with info.several people have done this but with lack of info and barely any pics.tried to search for pertinet info on the 200cc lifan here with no luck.so did all the research myself,and came through for myself.when i post the next post it will contain all the info with pics.come back later to see.if this is a project you are about to do,check and see the follow up.
    1985 ATC 250R
    . Team Red Trike
    Feb 2009
    michigan
    2,387
    thinking liffan read this
    ok here we go.i will post everything i did to put a 200cc liffan into a honda 185s.this was a great project,and glad i did it.first i removed a very tired 185s motor.next i purchased a 200cc liffan off e bay.cost a little over 400.00 to my door.327.00 plus ship.started redo on Saturday and wrapped up on Sunday.motor install pretty easy,just had to notch frame crossmember a 1/2 inch,and in she went.next the carb boot would not work so i used the 185s boot,perfect.wired up color for color for the most part.if not using battery or electric start just use the 5 wire harness.dont need anything off the 6 wire harness.i tucked away for future use.motor has two wiring harnesses.after that i noticed a clutch problem,[not engaging].had to take side cover off and see.guess it was last motor of the shift at the factory because the clutch actuator was not touching the lifter rod in the clutch,easy fix.hooked up everything but the chain.waiting for new front sprocket.motor come with 420 chain sprocket and i have brand new 520 chain and rear,so i was not changing those.found a company that sells liffan sprockets that have 520chain stuff.company is hooper imports,here are some pics of the rebuild.
    Attached Thumbnails Attached Thumbnails 0710090920.jpg   0710091013.jpg   0710091032.jpg   0712091842.jpg   0712091844.jpg   0712091856.jpg
    1985 ATC 250R
    . Team Red Trike
    louisiana
    1,499
    looks real good man,nice work.
    Signature pic removed,becuase of no helmet.
    Sep 2007
    100mi west of Chicago
    3,582
    Looks pretty good. Is that a manual clutch engine?
    Rob
    Feb 2009
    michigan
    2,387
    185s
    Quote Originally Posted by rdlsz24 View Post
    Rob
    yes it is a five speed manual
    1985 ATC 250R
    . Team Red Trike
    Lewiston, N.Y.
    1,477
    How do these engines sound in comparison to the stock ones? I dont know about them but i have heard they are much faster, so i would think they sounds 'ballsier'???
    Jim
    Feb 2003
    Australia
    927
    The pushrod engines like this one are sluggish. The overhead cam ones go well.
    Feb 2009
    michigan
    2,387
    sluggish?
    dont know about that.she wheely's in first three gears,dont know what you heard but,wrong.
    1985 ATC 250R
    . Team Red Trike
    Feb 2009
    michigan
    2,387
    update 185s w/liffan
    when i put motor in used the kiehn carb i had on the 185s.works great no rejet needed.plug has nice carmel appearence.also have to find a 12volt rectifier for the accessory circuit,i.e. lights and tail light.the pink wire is 12-30 volts ac.from an idle to full rev.
    1985 ATC 250R
    . Team Red Trike
    Feb 2003
    Australia
    927
    Well, you would love the OHC version. They wheelie in all five gears. They are much faster than the old school push rod engines.
    louisiana
    1,499
    greenhuman are you talking about the original 200x engine??
