Results 1 to 12 of 12
Thread: HONDA 5HP OHC motor help....
    I had to tear down my 5HP OHC Honda horizontal shaft pressure washer.
    I put it back together and the governor is not working.
    It seems to work off of RPM, throws out a weight, turns a shaft and regulates the throttle position.
    To me, I should be able to take the play out in one direction and it should do it's job. I cannot find marks, dots, lines etc etc to get this aligned if nheed be, but again, I feel it works off of RPM's PERIOD!!
    I've searched online online to spend 2 hours on useless junk......
    Any input would be LOVELY and no, I'm NOT buying a manual.............
    Thanks for any help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
    Monroe MI
    5,786
    A model/serial number of both the power washer and the engine itself would help.
    Nov 2007
    ulysses pa
    1,231
    did you remove the arm from the shaft going into your motor?
    Jan 2005
    RI
    2,530
    steve i think those have to be preloaded or something stupid like that?
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jan 2005
    RI
    2,530
    here you go asshole...took me 3 mins to find it...
    http://en.allexperts.com/q/Small-Eng...-5HP-OHC-1.htm
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Sep 2003
    Elizabethtown PA
    1,581
    post up some pics. i have a bunch of honda 5 horse push mowers sitting aorund that i am fixing to sell. honda GXV 140's is what is stamped on the side of the motor. maybe i could look on there to see if you have something wrong
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    It's an XR2500 series.
    I did remove the arm from the shaft.
    Mike, your link suks........
    Thanks
    Mar 2005
    ma
    988
    you shouldn't have removed the governor arm from the shaft. theres no reason to, unless your replacing the governor. and only idiots fool wth it. i've had to fix so many engines where people think they know what there doing and move the governor arm. and thats never the problem, it just makes it run worse. and escpecially on a honda, theres to many springs and crap to get screwed up. now i'll help after i rambled on!
    you have to put it at full throttle, loosen the governor shaft clamp(the bolt that clamps it to the shaft) and turn the shaft either to the right or left, all the way. i forget exactly how a honda goes. they don't need fixing much! but you have a 50/50 chance. just make sure you don't over rev the engine.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    Monroe MI
    5,786
    I found some Honda shop manuals, I think you have a GC160 engine, (if not, there's more models there). Not sure if this will help you.
    http://www.honda-engines-eu.com/en/s...tion/index.jsp
    Straight to the GC160 http://www.honda-engines-eu.com/en/images/991.pdf
    Check page 90
    Jan 2005
    RI
    2,530
    from that manual...
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Thanks for all the help.....
    Mine has no throttle arm, it's on a pressure washer. The throttle is controlled solely by the engine RPM's (IMO)
    I had to remove the arm, or I would have had to deal with linkages and other springs etc to get the case cover off.
    I'll dick with it a bit today, thanks again
    Apr 2008
    somerset ma
    1,822
    If you can't get it right, I'll take it off of your hands an slap that biotch on my go-cart and let it rip!!
