Just had the carb off my BR. Pulled it down, cleaned the snot out of it and put a new choke valve and a rebuild kit into it... Put it back on the trike, gave it one kick and it idled about 200 rpms high... Pretty darn minor... Took it for a test ride, and in low gear, from idle to 1/4 throttle it has a little bog, and then it pulls like everything. Its not as noticable in second and third. Even get a occasional burp out of it in those low rpms, but runs great through the mid to top end. My question being, does it sound like it is a needle adjustment issue, crap in the low speed needle, or what about the synchronizing between the butteryfly and the slide....? Any suggestions are greatly appreciated...
