Broke the chain on my 250r so time for a new one. What kind of chain do you guys run on your bikes and anyone got any tips when looking for a new chain?
Matt
Matt
1980 ATC 70 Needs Restoration
1985 ATC 250es Fully Refurbed
1986 ATC 350x Mint Original
Always O-ring...
1986 ATC500X
1985 ATC250SX
1985 ATC200X
1985 ATC250R
1986 ATC250R
1984 ATC250R
1981 ATC70
1984 ATC70
1985 ATC70
Custom built ATC70 / 250R laydwon swap
1986 ATC250SX FATCAT
My rule of thumb is, the longer you want the chain to last, the better quality chain you buy up front. If you are racing, you will buy quality chains way more than the normal recreational rider. I have access to free chain, so a little maintenance in the way of cleaning and some oiling and the cheap stuff works good for me and I just change the chain as often as I need to. A quality, meaning expensive chain will last longer, but no chain is meant to be left outside in the rain and elements all the time, so let that weigh in towards the kind of chain you buy. If you drive through lots of deep water, an o-ring chain won't help you much either. The best advice for a cahin is, no matter what you buy, occasional cleaning with a plastic bristled brush and regular oiling with chain lube or lite machne oil will go along way to give your chain a long and healthy life.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
I also get free chain from work, a littla more maintenance, but it works for me.
i have torn most chain brands in the past while racing and the one i have now seems as good as any.
DID profesionial, but like veal said get ready to pay for a good one.
WWW.HREATV.COM
Yup, I have a D.I.D. o-ring on my 350x.
84 Honda 200ES Big Red
I just bought a DID X ring for my R build, Expensive? Yes, but with the amount of riding I do it will be the last chain I ever buy for it.
My Rides
-under restoration
-Paul Turner pipe
-+2" Westcoast
1985 Green Tecate Sold
My Wife's Ride
My Kids Ride
I put a DID O-ring chain that is going on my 200x build. I figured the money up front should help me out when it's getting beat through the woods.
YTM-200, Wheeling machine!!!
1985 Honda 200x...
...Just a simple mild 200x
I had run DID professional chains in the past. 7700 pound tensile strength. I did some shopping around a while back and found that the Primary Drive chains from rocky Mountain atv have a tensile strength of 8800 pounds. (less stretching) In the local cycle shop, Did chains (non-O-ring) sell for 80.00, at RMATV they sell for 35.00. Oring chain at the shop runs 115.00 and RMATV has them for 45.00. I have never had an issue with any 520 chain I purchased from them.
I highly recommend them for chain. I will only buy chains from them now.
Charlie Don't Trike
85' ATC 350X
85' ATC 250SX
85' YTM 225DX (sweetie)
84' ATC 200 auto X
85' ATC 70
85' YT 60
My Partz Auctions
C'mon buddy, do a search...
http://www.3wheelerworldforums.com/s...ad.php?t=95884
colored chain off of ebay
Feedback thread: http://www.3wheelerworldforums.com/s...ad.php?t=78535
Patiently waiting..
I run a Renthal Supercross chain on my R. They don't make that chain anymore but when its time for my next one I'm going with either a Renthal R1 Works or R4 ATV chain. If two chains are made from the same materials and one is O-ring and one isn't , the NON O-ring one will be stronger. The main benefit of an O-ring chain is that it keeps the dirt and grime out of the pins. My R only sees the ice and once every few years it sees the dunes in Michigan so an O-ring is unnecessary and actually uses more power to turn.
My X goes in mud and woods every time I use it so I run an X-ring on that.
Remember, a good chain and sprocket set up is way cheaper than fixing a hole in your case. Besides, you'll get so much more life out of a good chain that it ends up being cheaper than buying a couple of cheap ones when you add in the cost of buying new sprockets twice.
John
1985 Eddie Sanders ATC330r
1986 Monstecate
1984 ATC70 (awaiting 125cc transplant)
1984 ATC125M
1986 GSXR 750 - Keepin' it old school!
1999 Arctic Cat 500 4x4 plow machine
1999 Arctic Cat Thundercat 1000 (lake lizard)
1996 Arctic Cat Jag 440 L/C (ditch banger)
Rockey mountain.....gold! 46.00 dollars 8000 pounds of strength.
1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
I run a Primary Drive gold X-ring chain
1985 Honda 200x
- 30mm Carb
- DG Exhaust
- Rear Wheel Spacers
- K & N Filter
