Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Thread: Awesome Carb Cleaner Rust Remover!!
    OHIO
    2,857
    Got this at Tractor supply. Evapo rust........ no fumes, easy on the hands an man it worked awesome on a 70 carb in a matter of hours!! 20.00 for the gallon but I will reuse for sure. Got some in the 110 project tank, will see how it works as well. Give it a try....
    Mar 2008
    EastGreenbush, newyork
    3,494
    Ive used it, there is a thread on hear about it, works awsome, I did the inside of my 200e tank with it came out like new.
    OHIO
    2,857
    ya man, that stuff kicks arsss... I know what I will use from now on.....
    Terryville,CT
    1,616
    that is what its called evapo rust?? at tractor supply eh?
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Apr 2008
    somerset ma
    1,822
    So,, seing that this stuff is so good at removing rust,, do you think if I put it on my current frame, it will make it vanish??? rusty skupper!!
    Oct 2008
    NB, Canada
    852
    I saw that stuff at Canadian Tire, but I didn't know how well it would work. I'll try it on my 200m tank to get the rust out, I'm currently running on rust color gas.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    OHIO
    2,857
    Don't know if it would work on frame....needs submersed. You would need 438 gallons to cover a 350x lol lol just kidding....... here is a pic of it if it will help....
    Carrollton Texas
    76
    i have used it and i just finished dropping a bunch of rusty bolts in a plastic cup with this stuff and works great, they come out looking like new (overnight) . i did all the bolts on my 85 R with about half of the small bottle.. once it stops working it will start forming like a white milky looking substance on the surface of the liquid , then you know its time to replace it with some fresh juice ..
    because 3 wheels are better than 4
    Mar 2009
    Sioux Falls SD
    41
    i have an old cylinder that has some rust inside it. would it work to use on that or is it too strong? is it harmful to bearings?
    OHIO
    2,857
    I used it on carb and it did no damage on rubber gasket, I left on on to see whay would happen? It is pretty safe stuff....... would not be afraid to try on cylinder or head??
    Mar 2009
    Utah
    203
    i just bought some and dropped these in there.
    i'll show you the results in a few hours. those are muffler guards btw.
    3 wheelers:
    '85 ATC 110 (its my first restoration!!)
    Saving up for a 250r later this year!
    Jan 2008
    nc
    734
    Mar 2009
    Utah
    203
    Exclamation Here they are!!!!
    After two days of soaking (due the fact that i had to flip them over to get all the rust) look!! they're close to shiny clean!!!
    Look what it did to the Evapo Rust too. Haha! Not very reusable
    3 wheelers:
    Feb 2009
    michigan
    2,387
    evapo rust
    im going to get some in the morning.got a few projects in mind.
    1985 ATC 250R
    . Team Red Trike
    Monroe MI
    5,787
    If you clean the parts first, the solution will last longer. Also, even though it looks dirty, the solution will still clean, it just takes longer (to a certain point).
