Results 1 to 15 of 15
Thread: rims: whats the trick to make them seal
    1985BigRed250ES's Avatar
    1985BigRed250ES is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Rison, Arkansas, United States
    397
    The rear rims on my ATC 110 both leak where the two halves come together. I have put new 'O'-rings in them and could not get them to seal. i took them back apart and put high temp silicone in the groove with the 'O'-ring still in the rims and put them back together. I still cannot get them to seal. whats the trick? the groove in the rims are clean and no rust.
    Jordan
    1985 Honda BigRed 250ES
    runs good all original
    Restoration in progress:
    1980 Honda ATC 110
    1985 Honda ATC 250SX
    1982 Honda 200ES BigRed
    1984 Honda 200S
    1984 Honda 200S parts bike
    1985 Honda ATC 110
    1983 Honda ATC 110 parts bike, runs but smokes
    Feedback link: http://www.3wheelerworldforums.com/s...ad.php?t=95258
    pudge is offline At The Back Of The Pack Arm chair racerFirst time rider
    CT
    159
    get tubes. you dont want to keep adding weight with slime, fix a flat, sealents..... its just easier
    Apr 2008
    NW, IND.
    842
    Sounds like you sealed the center of the rim, how about edge and the air valve. I use a large garbage can 1/2 full of clean water and roll the tire in there and look for leaks.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Aug 2004
    Ab Canada
    4,368
    Roofing tar in the cocking tube deal
    1985 Tri-Z-
    Dec 2002
    deer park, texas
    2,336
    Your problem will most likely be around the lip. Take a close look at this area. I have had more trouble out of that then the center. Sand it, clean it, whatever you can do to make the surface area clean.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    for the bead, use bead sealer. for the center halfs, roofing tar or some RTV silicone FTW.
    just fill a spray bottle with soapy water, and spray around and look for leaks.
    piss on tubes......way easier to fix a nail with a tubeless tire
    louisiana
    1,499
    rims
    i had the same problem with 3 sets of tires leaking.this is what i've done and it works perfect each time.take the rims of the tires,split the rims in half.take a wire wheel on a grinder(4 1/2 inch grinder with wire wheel fits just right down inside the rim if you want to go ahead and paint the outside of the rims while they are broke down)clean the whole inside rim and pay close attention where the halves meet and where the bead is.spray some the whole inside rim with etch primer so that it want rust later on.take one rim and set it back down in the tire and silicon wher the halves meet,set the othe rim down on top of the first half inside the tire,put your bolts in to make sure they are all lined up but dont tighten anything down yet,let the silicon cure or dry for about 20-30 mins depending on the temp.after it has dried snug the bolts and inflat and your ready to go.couple pictures of the last rims i've done.Click image for larger version.
Name:	rim finished.JPG
    ^ Where do you guys buy "bead sealer" - I can NEVER seem to get the same chit the tire shop uses.... I use the "seam sealer" from Carlisle roofing.
    Do not run tubes ever ever ever ever!! It will be 15-25$ for the tube, another 10-20$ for a tire shop to install them if you can't break the bead. An one mistake and the valve stem is sheared off, be it steel or rubber.
    I've run them, I've used them, I've tried them in desperation to salvage 60$ tires and they have failed in 75% of these installations.......
    397
    Quote Originally Posted by leevarnado View Post
    Thanks for the info guys. I willl try this soon. What kind of paint are you using on those rims? they look great! Right now I have the motor out of the frame getting it ready for the head. I will be cleaning the frame and repainting it too. What kind of paint to use here? I think powder coat might be a little expensive?
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Aug 2004
    Ab Canada
    4,368
    you will have to look around for bead sealer, any supplie shop for tires should be able to hook you up, it works ok on alum rims ect, the tar is the last resort but works good!,
    1985 Tri-Z-
    louisiana
    1,499
    i used high temp paint.its cheap and looks good but doesnt last as long as other painting technics.i heard good things about por 15.soon as i get my spay guns back i going to give it a try.will let you know what the ends results are.
    397
    thanks guys, I will be trying something soon on the rims.
    1980 Honda ATC 110
    1984 Honda 200S
    1985 Honda ATC 110
    Mar 2005
    overton, PA
    5,257
    wow this seems liek ateam red rider post lol
    Quote Originally Posted by pudge View Post
    So a tube weighs less than slime?
    What most of these guys are telling you is the right thing to do. Clean 'em up, prime or paint 'em or whatever you're gonna do, that's that. If all else fails, Slime works great for me. I have it in several of my wheels. Some people say slime eats the metal but I personally have yet to see any proof of this. I'll let you know when my wheels rot off.
    Howdy's Avatar
    Celina, Ohio
    10,079
    I apply a few coats of Hi-Tac and let it dry. Once dry I put the o-ring on it and assemble it. Only ever had one leak after doing this way.
    The only other way I have fixed them is via tubes.
    Howdy
