Results 1 to 15 of 16
Thread: what do they do to port a two stroke? also reed cage question
    NE Indiana
    1,067
    I understand porting on a four stroke engine but There is no valves on a 2 stroke I just don't get it. Do they just gently grind off any manufacture flash or something?
    I want to upgrade my reeds. I noticed someone selling a reed cage with their performance reeds that supposedly increased power. It that true? Or is is a gimmick, i thought the reeds are what mattered. Is is best to replace the reed cage and reeds with performance ones for best gains?
    What are good reeds to get?
    Nov 2006
    southern oregon
    2,338
    Well unlike a 4-stroke the piston does the job of the valves... The ports on a 2-stroke combined with the pipe basically performs the function of the cylinder head and cams of a 4-stroke.. 2stroke porting usually involves removing casting imperfections and other flow obstructions as well as alterering the shape and sizes of ports to achieve the desired results.. porting works in conjuntion with other variables such as the pipe, head, and intake system to control what rpm range the engine makes power and how broad the powerband is... Higher rpm power gains are usually a trade off for low speed perfomance and vise versa...
    2-stroke lover
    NE Indiana
    1,067
    Quote Originally Posted by cr480r View Post
    I see. So a novice doesn't want to go in and lightly remove some casting imperfections or flash because it could screw it all up?
    Apr 2008
    NW, IND.
    842
    Not at all. You can take emery cloth and lightly smooth your exhaust port. Take bluing ink and match the header. Doesn't hurt a thing.There is a book called Two Stroke Performance Tuning by A. Graham Bell. It mostly talks about twin cyl. and cart engines, but gives you the basics to tuning and light mods to the stock engines. Good book $20- Amazon. Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Aug 2004
    Ab Canada
    4,368
    Lighter reeds generally give you a crisper throttle response, not much in the hp gains, it helps to match the "ports" on the reedcage with the pedals for better flow, you have to watch on some bigger bore 2 strokes iv found fiber reeds to flutter under hard decel causing a nice eratic poping,
    1985 Tri-Z-
    Mar 2005
    overton, PA
    5,257
    well dependign what sort of power toug going for you can widen the ports, raise them for a mor etop end scream, change transfer port height and angles to modify the power delivery and found otu that the crankcase also has alottttt to do with the power delivery inmy experiments also i picked up almot 4 hp by reducign the dead volume in the crankcase. it is also calle dpackign the crankcase. but it also make sit a catastrphe if somethign small goes trough the motor. but also dependign on if your lookign for a fullout drag port its raise the exhaust port and make it flow as much as possible and chenge the size and angle of the transfer ports. and also may include adding boost ports into the intake sid eof the cylinder between the reeds and piston dependign on the motor. i know quite a bit of info on this just dont knwo how to out it into words.
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by Hoosier_Daddy View Post
    I would remove all the imperfections.. it will help just dont expect huge gains from a simple clean up.. The main thing is just dont make modifications the shape or sizes of the port windows unless you thoroughly understand why you are doing it.. and what the results will be.. As mentioned above alot of info on the basics can be learned by reading books and finding bits and peices of info on the web..
    2-stroke lover
    Nov 2006
    southern oregon
    2,338
    Quote Originally Posted by brapp View Post
    I have my 480 apart right now doing porting and some things to stuff the crankcase.. Do you think its possible to over-stuff an engine? I think with an outdated pipe design it would be difficult...
    2-stroke lover
    Shawn72's Avatar
    Shawn72 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Lawton, Ok
    392
    I can't talk much about the technical aspects of porting, but a set of boyesen Pro reeds will def help your throttle response alot. Instant power.
    It's a celebration bitches!!!
    Derek's Avatar
    Derek is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2006
    Boston NY
    164
    Quote Originally Posted by Shawn72 View Post
    I agree, I'm running a set of Boyesen Pro Series carbon fiber reeds in my RM125. They are way better than stock.
    1985 Honda 200x
    - 30mm Carb
    - DG Exhaust
    - Rear Wheel Spacers
    - K & N Filter
    NE Indiana
    1,067
    You guys are greatly helpful. Thank you. And boysen pro series reeds it is. lol
    Nov 2008
    Coon Rapids, MN
    956
    I agree on the reeds it made my trike much snappier.
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Mar 2005
    overton, PA
    5,257
    480 you can over stuff the cases by taking away and makignt he tolerances so tight that th crank lobes rub the packing materialswether it be a sleave or weld or what not. et your tolerances too close and it will expand under heat and will rub. i always say .030 ths minimum
    NE Indiana
    1,067
    OK, to be more specific, this reed cage for my T3. Is it overkill? Or should I keep the stock cage and go with pro series reeds?
    http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
    Apr 2008
    NW, IND.
    842
    I would call Boysen reeds and ask. They are very nice people.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
