Results 1 to 15 of 21
Thread: Tricks to install new grips?
    MA
    384
    I have the old ones off... but I just can't get the new ones on. They are the correct size (have one slightly larger for the twist throttle).
    I get them on 1" or so and get stuck.
    What do you guys do to get them on?
    kokmatt is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2008
    Sioux Falls SD
    196
    i use brake cleaner to clean off the handlebars real well then spray a little in the grip and slide them on. but not sure if brake cleaner will do anything to the plastic of twist throttle. after you get them on let them sit and the brake cleaner will dry up and they usually dont move after that.
    85 Tri-z
    85 Tri-z with Astro Kit
    MA
    384
    Hmm, wonder if that hurts the rubber on the grips? That stuff is caustic haha
    Feb 2009
    florida
    20
    try soapy water...thats what i did when i used to motocross
    Nov 2008
    ontario
    1,055
    i used hair spray its slippery but dries up after
    proud owner of a trx300ex quad and an 85 atc 70
    Terryville,CT
    1,616
    I use compressed air lift up the grip alittle put your air nozzle if you have a blast nozzle blow gun what have you under the grip alittle then blast and pull works great if you have a person there to pull the grip when you blast the air!! or hairspray if the woman has any use that it will dry tacky on the inside as well!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Sep 2008
    Buffalo
    808
    +1 for Hairspray. I just did new grips on both my 350x and 250r the other day. Spray the bar with a nice high rated strong hold hairspray and you'll be good to go. I been using hairspray since the BMX days
    Tpc 450
    86 250r
    86 350x
    86 200x
    86 250sx
    85 225DR
    (2) 84 YTM
    (3) 85 Atc 70
    MA
    384
    Ok cool. I'll do that up.
    Apr 2007
    Lykens, PA
    87
    Compressed air works wonders. Poke a small hole in one end of the grip on only one grip. Block the opposite end of the handlebar with hand and put the grip on, and blow air in the hole. Slides right on.
    Than for the other end put finger over the hole in the grip. and do the same as the other side.
    Real simple and no mess to deal with.
    84' Yamaha Tri-zinger 60
    85' Honda ATC 70
    84' Honda ATC 70
    83' Honda ATC 70
    78' Honda ATC 70 (140cc lifan)
    79' Honda ATC 70
    73' Honda ATC 70
    85' Honda 200s
    83' Honda 200e
    85' Honda 250sx
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Thank for the advices guys, I need to put new grips on my 225.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Mar 2005
    overton, PA
    5,257
    i have used hairsprey, spray paint, and gorilla glue.
    Apr 2006
    Crestview, Florida
    2,429
    spit on it. lol
    Rides
    85 ATC350X
    85 ATC200X
    OK
    5,450
    I have used spray paint for 20+ years and have never had one come off. Spray paint into the grip put it on, wipe it off. Done.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Jul 2008
    Sweden, Västerbotten, Skellefteå
    61
    I usually use methanol (also dries up nice compared to oilier stuff) to lube things up when sliding it on and for taking it off i use a syringe u can slide that in pump some methanol in there and it will come off easy.
    /Johan
    Baltimore, MD
    6,088
    I use the hairspray method to install and use air or wd40 sprayed between the grip and handlebars to remove.
