got my new piston and ring set it, got 2 small questions..
1. the "spacer" for the oil ring, can or should it be overlapped?
2. the top 2 rings only have "T" stamped on them, one of them has a closer gap than the other, which should go on top?
1984 200ES first Shaft driven big red with reverse!
85 Big Red 250ES with a rebuilt top end!
The "spacer" should not overlap. The end should be butted like a W. The T goes up, didnt the piston come with instructions? And what is it for?
1986 200x- old school D.I.D wheels, Gold D.I.D X-Ring Chain, Rad MFG. Carrier, PRM Grab Bar, Pro Circuit T-4 custom, Maier plastics, 85x forks, 18x10.5x8 kenda klaw mxr's on itp steels, the money pit never ends![]()
no instructions, for my 200es
got the 'w" correct, its a shady shidy from JAPAN!
Hm, most pistons come with atleast the gap specs. Anyway the top compression ring usually has a larger gap than the second one. Is one ring fatter than the other, that would be an easy way to figure out. And dont forget to gap the rings! That can lead to bad problems later on.
they are the same thickness, like I said, one has a significant gap than the other, so what u r saying is that the top ring should have the largest gap?
do you have a manual? If not you should get one. It will help out alot.
81' Honda 250r
84' Honda 200x...sold
84' Honda 200s...sold
Yeah buy a manual. But right off my wiseco paper for my 200x it says .0040 for top and .0050 for bottom, so bottom would be larger Im assuming, and it just says for dirt,atv,snow and PWC. So I guess that would be what you want for yours. I guess I was wrong about top being bigger? I could have swore my 450 piston ring was larger on top.
compression rings are normally a different color like gold or silver
scraper rings are normally just black
WWW.HREATV.COM
I have looked at the honda manual, I wanted some hands on experience. The manual shows the end of the piston ring slanted for the the top one. Both of my rings have straight edges, only difference is gap size!
The top ring is usually shiny as Swigin posted....
WWW.HREATV.COM
my eye is not that great naked, I just need to know if the ring with the largest gap goes on top, or bottom (of the 2 compression rings)
ok i know what he's talking about. i worke don one of them lesser piston sets before.
both rins are the exact same thickness. the one with the bigger gap goes to the top.make sure the gaps do NOT match up. they shoudl be nearly 180 out.
make sure the 2 small rings are on either side of the oil ring expander. the side in a groove on either side and kinda on tope. if you look closely at it you will see the part that goes against the piston is slightly thicker than the top you see when it's installed. the 2 tiny rings will sit on either side of that top thinner peice but on top of the bottom section. thhat bottom section allows the oil to touch the sidewalls and the rings on either side are called whippers.
is there any marking on the rings at all? if there are any parkings. (stapmed or printed) they go facing up. if not, then there's no direction on the rings.
________________
https://www.mikesatvfix.com
the gaps mean nothing...if he switchs them up it will never seal up.
WWW.HREATV.COM
