Page 3 of 3 FirstFirst 1 2 3
Results 31 to 43 of 43
Thread: interco vampire tire
  1. #31
    acidburn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Cornwall
    344
    ok so off of ebay i have a choice of mud bugs, mudzillas or mud lite.
    so witch to choose how the tread wear on em *i hardly ever ride on pavement mabey like 2-3blocks of roads untill i hit the trails*
  2. #32
    Pensacola, Florida
    124
    the mudzillas will out do the bugs or the mudlites. the bugs will out do the mud lites and the mudlites dont out do much except a stock tire.
  3. #33
    Cornwall
    344
    i found another tire, kenda bear claw ne one try these out?
  4. #34
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    What model bike?
    185 , 200 std and 200m can be geared for the heavies.
    Vamps digg. No bottom no forward motion.
    GBC Gators will float and paddle.
    Mudzillas will dig if you get enough wheelspin, but there really heavy.
    Mudlites are a general purpose tire, same as the swamplites.
    GBC Dirt Devils work surprisingly well. There a general purpose, heavier then the mudlites but work much better. Cheap aswell. Ran set on my atc200e for a season and they worked awesome.
  5. #35
    Oct 2007
    Grosse Tete, LA
    3,440
    Quote Originally Posted by Coaltrain View Post
    yeah...sorry, but with an inch and a half of grip, and being the same weight as stock tire...you can spin the ever loving hell out of them AND they dig.
  6. #36
    Pensacola, Florida
    124
    Quote Originally Posted by The Goat View Post
    I must be confused Mr. Goat, I thought we were discussing tires in the 25x12-9 range. If that is still the case then the mudlites only have 3/4" tread in that size, thats not quite 1 1/2" now is it??? Oh well let me assume you do know what your talking about and mudlites do come in 1 1/2" tread depth then maybe it is on their larger ones. Nope, just checked itp's site and the "big" mudlites are only 1 1/8" deep. Thats still not quite 1 1/2" that you claim so lets dig a little deeper, maybe its on the very biggest mudlite they make the 30" tall model (even though we weren't talking about 30" tires). Nope not on the 30" model either, seems it is only 1.3" deep.
    http://www.itptires.com/utilityatv/mudlite.html
    I still stand by what I said about the mudlites. since we are talking about a stock size replacement tire, the mudlites that are stock replacement size will out do the stock tire usually but not much else.
  7. #37
    Jun 2003
    Anchorage/Homer, Alaska
    480
    I run 25x12.5x9 Kenda Bear Claws on my SX. They work awesome in mud, snow, soft terrain, even water crossings. They definately hold up to hard trail riding and abuse. The tread is aggressive, but I think they ride just fine.
    I will be buying another set my other SX. What other endorsement could I give?
    The pic on the right is at 3000ft. ASL. The Kendas do good on rocks too!
    Attached Thumbnails Attached Thumbnails l_08d19d74b6f97fffda1104443a0d1c6b.jpg   l_92448ba7d24a8cc6f14cc88837bf8c54.jpg
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
  8. #38
    Oct 2007
    Grosse Tete, LA
    3,440
    easy little buddy....measure an inflated 25in XL......it's a bit more than 1 1/8.
    as for the kenda bearclaws....they are a damned good tire...but they also weigh the same if not more than the vamps.
  9. #39
    Cornwall
    344
    so its down to 2 choices * if they havent been disscontinued yet...*
    GBC dirt devil 2 - 23lbs
    KENDA bearclaw - 28lbs
    would that extra 10lbs from the claws help in ruts since with the stock goodyears i found my self always bouncing my ass end or would the ddevils be a better over all choice.
  10. #40
    Oct 2007
    Grosse Tete, LA
    3,440
    have you considered outlaws?
    I ran 22x12x10 bearclaws on a 250 yamaha. Ran em at 1psi. They were over 14 inches wide...and they slide really well when out of the mud. I always found they would keep going where others failed just because of the width. But at 22in I could spin them reved out in second...
    The issue you're going to have is spinning them. They are HEAVY!
  11. #41
    Cornwall
    344
    i have never seen the outlaws in my sizes and i dont believe the shop around here can order them, they couldnt even order from interco -.-. anyways hes currently looking up the bearclaws and dirt devils 2 for me i really want the dirt devils 2 they seem to have a real nice tread and weight. but bearclaws are my last resort
  12. #42
    Nov 2007
    ulysses pa
    1,231
    acidburn, i cant comment on any other tire than the dirt devils. i run these on my 200x and a friend has them on his 250sx. i am really impressed with the tire for the type of terrain i ride in. we have extremely rocky terrain with alot of mud and streams, steep hill climbs, hard packed roads, and tons of snow in the winter. i've had mine for 2 seasons and there still goin strong. rarely do i get stuck and i run out of power climbing long before i lose traction. in my opinion, you wont be disapointed in the DD2's.
  13. #43
    Apr 2006
    Maine
    440
    Might want to consider the regular Dirt Devils over the 2's if your going to be in the muddy stuff. While a little heavier and the same lug profile they have a larger void spacing and will clean better in the muck. Can't ask for much more.
