Results 1 to 12 of 12
Thread: HOW TO? Manual clutch atc 110
    the tecate kid's Avatar
    the tecate kid is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2007
    Cincinnati, OHIO
    406
    I know it is relatively easy to find a sl 70 and sl 90 and put a manual clutch in an atc 70/90, but what about the 110? From what I've gathered, they are not interchangeable. Any ideas how to accomplish this? My son has a pretty hot little 84 110 with lots of old school goodies on it, but he would like a clutch for more control. Any help would be appreciated.
    Been There...Dug That.
    Jul 2004
    Pride, Louisiana
    286
    A buddy of mine bought a 110cc dirt bike that has a Chinese made engine. Looks identical to a 110cc Honda motor but has kick start and manual clutch.
    1977 ATC 90
    1983 ATC200E Big Red
    1985 Heald Super Bronc VT-10
    1999 Bayou 220
    2007 Polaris Outlaw 90
    Baltimore, MD
    6,088
    You have to change to different cases. No 2 ways about it.
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Quote Originally Posted by cajun66 View Post
    yes these are the lifan motors that a couple different people have put in their x's and s's and what not. by the sounds of things this 110 he has now already has some good stuff in it which is why he doesnt want to swap motors.
    anything can be done, its just gonna take some fab work. i know there was a kit aguy developed for the yami wolverine 350 to convert it to a manual setup (the wolverine motor is basically the same as the warrior) that would be my ideal 4x4, a worked manual wolverine.
    anyhow the conversion for the 110 should be similar to that wolverine/warrior swap. maybe you shoul try to research that to get an idea. i may actually have the article in an old dirtwheels, i'll check.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Apr 2007
    Cincinnati, OHIO
    406
    You mean switch to the 90 cases? If so, will it bolt up to my frame? How involved is it? Do you have any extras laying around Pat?
    Baltimore, MD
    6,088
    You would have to bore the spigot out for the larger 110 cylinder at least. I'm not sure if the 110 crank would fit, but it should, at least for the points style 110, cause I'm not sure if the cdi 110 crank ends are different, that would be the big problem. You would have to research that.
    Apr 2007
    Cincinnati, OHIO
    406
    Tri-Z pilot I looked through my old 80 and 81 dirt wheels and couldnt find any articles on the swap. I know it has been done though. Anybody else out there ever done one of these?
    Feb 2003
    Australia
    927
    The 110 manual clutch conversion is the same as the old ATC 90 conversion. Get an old manual 90 road bike engine or clutch cover and clutch pack. The only mods to do are shortening the inner end of the ATC shift shaft ( on the ATC the shaft is supported by the auto clutch cover, on the road 90 its not) and put a welsh plug in the manual clutch cover kicker hole.
    Make sure you get a manual cover with the alloy cable mount intact. They had a habit of snapping off.
    None of the Chinese 110/90 parts are interchangable with the ATC110 engines.
    Apr 2007
    Cincinnati, OHIO
    406
    Thanks, got a lead today at my local motorcycle junkyard. For 20 bucks I cant go wrong! The guy said he didnt know if it would work with the cdi ignition or not. Worth a try though.
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by greenhuman View Post
    Thats all? I am going to have to give that a shot. Is it the same for the 84-85 125m motor? I seems like it would be.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jun 2006
    Willow, Alaska
    1,336
    On egay there is a kit to convert the 110 Lifan engines to manual clutch, I think it was like 80$ and had everything you needed. Seeing as they are the same as the Honda motors, it should bolt right on and work the same?? Just another option if you dont want to buy used stuff.
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Feb 2003
    Australia
    927
    The chinese 90/110 copies are based on the Honda 70 engine. A completely different animal to the Honda 90/110. Nothing interchanges.
