Results 1 to 14 of 14
Thread: Removing Spray Paint from Plastics
    81k is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2008
    Bowling Green, MO U.S.A.
    152
    Some Dumba** painted all the plastics on the '84 Yamahauler I just got. I was wondering if anyone has any tips on removing it? I did a search on the forums but couldn't find anything. My daughter was scrubbing it with paint prewash and a rag, and she got alot off one side rear fender, but it took forever. Any help would be greatly be appreciated.
    YT 60
    '85 ATC 200X x2
    YF 60
    '02 400EX
    '85 YFM 200
    '99 Scrambler 400 4x4
    '85 350X
    Jul 2006
    there is a type of paint remover made for bumpers, you will have to get it from a local paint store, its the most non abrasive meathod other then a heate pressure washer to remove the paint.
    Dec 2007
    Southwestern NY
    517
    Well.... I recently purchased a complete set of banshee plastics that had been spry painted. I tried SEVERAL different methods, but the only thing that realy took the paint off was brake cleaner. I was worried about the brake cleaner drying out or dicoloring the plastic, so I worked in small sections. I would spray the brake cleaner on heavily, then wipe off the excess paint/cleaner with a brake cleaner soaked rag. Then i immediately wiped the area down with some generic vynal protectant. The plastics came very nice are are still shiny, no dulling or anything from the brake cleaner. thats the best i got...
    SAY IT!!!!!
    85 1/2 Tri-Z - The Trail Bike w/Inverts
    85 Tri-Z - The wifes Bike
    85 Tri-Z - The MX/ICE Bike, 310 w/Inverts
    12 Tri-Shee - The Flat Track/TT Bike w/Inverts
    NYTRO - New York Trike Racing Outlaws - COME GIT SOME!
    Sep 2006
    Northwest Indiana
    1,893
    Parmatex brand spray gasket remover. Comes in a blue can, and is availiable at autozone, advanced, napa, etc. Spray on and watch it bubble. Doesn't harm plastics at all, but will destroy decals in short order. The best method i've found.
    Mar 2005
    overton, PA
    5,257
    i have removed the plastics and sprayed the entireplastics with a paint stripper
    Oct 2008
    152
    I also used some brake fluid, let it soak in and it was working, but I was worried about damaging the plastics.
    YT 60
    '85 ATC 200X x2
    YF 60
    '02 400EX
    '85 YFM 200
    '85 350X
    Apr 2007
    Lykens, PA
    87
    I use carb cleaner..... Spray on, wait like 3sec and wipe off. And its cheap.
    Works on most spray paints,, there was one type of paint that it didnt work on though.
    Plastics off a 225dx looked brand new after.
    84' Yamaha Tri-zinger 60
    85' Honda ATC 70
    84' Honda ATC 70
    83' Honda ATC 70
    78' Honda ATC 70 (140cc lifan)
    79' Honda ATC 70
    73' Honda ATC 70
    85' Honda 200s
    83' Honda 200e
    85' Honda 250sx
    Mar 2008
    EastGreenbush, newyork
    3,494
    they sell vandalism removers in aresol cans but its hard to find, it works awsome though, large chem companies that supply comercial buildings with cleaning+ maintanance supplies usually have it.try searching "dynachem" dont know if there still in business. Ive heard walmart sells some kind of aircraft stripper that works but ive never tried it.
    Texas 200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Corpus Christi, Tx
    296
    M E K works excellent it will dissolve almost any paint and won't harm your plastics. You can get it at any hardware store. Its also safe on rubber.
    Hey, What other dangerously fun vehicles can I Cram in my 2and1/2-car shop? (Garage.)
    Feb 2008
    NW Indiana
    411
    The paint stripper from the auto parts store is called "Tal-Strip". They make two varieties. Tal-Strip II is the aircraft variety. It has a warning on the can about using it for composites so I stayed away from using it on my plastics. The regular Tal-Strip worked awesome on my big Red plastics, though. Spray on, watch it bubble, spray off with the hose.
    It didn't hurt the plastics at all.
    DarkestGKnight's Avatar
    DarkestGKnight is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Babylon
    448
    air craft stripper works well i have a can its about 8 bucks for a big can well worth the money.
    1982 yamaha rx50.
    2001 murray minibike with 5hp.
    fully modded goped.
    250cc 4 stroke shifter kart in the process.
    Apr 2006
    PA
    1,464
    3000 psi pressure washer.
    Nov 2002
    460
    Use oven cleaner the foaming type spray it on let it loosen the paint up and hose it off. works real good and wont hurt anything under it , i have used this trick alot try it Mike
    Apr 2004
    Brigham, Québec, Canada
    1,528
    I need to try one of those products on the fender of my big red, it is full of small grey spot.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
