School me on atc70 motor swaps...what fits?
Ive decided that I dont have the time or money to fix my 84 200x, and since I have an 86 200x, I am going to sell the 84 and use the $$ to finish my 70 that Ive always wanted. The engine thats in it 'runs'. Mostly when it feels like it. I know for a fact that it needs the ignition gone through, and the carb. Its hard to get started and when it finally does itll go for a bit then die, and wont run again unless it sits for a while. Is it worth fixing this engine, or would I be better off buying a Lifan or other Honda pitbike engine (XR70, etc)?
The engine I have would at least need points, carb kit or most likely a whole new carb, and probably other things (filter, maybe timing chain, which would lead to gasket kit, etc). Im not really a fan of points motors, and a new motor would basicly be bolt in and go, no rebuilding anything, which is why Im leaning towards dropping a new engine in.
I dont really care what the motors for, whether its a Lifan engine or a honda pit bike motor, but if I go this route the motor must NOT have electric start, and must have a clutch (no semi autos).
The questions I have if I dropped in a new motor are:
1. What engines could I put in that would require little to no mods? I think that the 125cc+ motors hit the front fender, would the 110s do this too? I also heard that front motor mount mods are necessary on some engines?
2. What are my options for starting? Does someone make an engine with pull start or forward kick, or is there a way it put it on? I do not want electric start.
3. Will the new engine's carb hit anything, and will I be able to use my stock airbox? Will I have to use the original intake for carb clearance?
4. Are there any other issues I would need to address? Like wiring, exhaust, throttle cable, or other?
-Nick
1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
