Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
Thread: Tire review thread. Based on experience.
    Jul 2004
    Pride, Louisiana
    286
    Post a review of the tires you are using, what you use them for, and pros and cons.
    "ITP MUDLITES"
    On my 185S I have a set of 22/11/8 ITP Mudlites that are 3 years old and no signs of dry rot. They do great in mud and brush. Ride a little hard on dirt and asphalt. And tend to dig in sand. They live up to their name being light. Also pretty cheap, 45 bucks a piece at the local ATV outfitter.
    The front tire is a Cheng Shin knobby. Good front tire overall.
    "DURO HF240A KNOBBY"
    The ATC200 has a complete set of 25/12/9 Duro HF240A knobbies. High floatation. Do great in every terrain I've put them in so far. A little weak in loose mud but not terrible. Ride is good. Wide spaced blocks do great in sand. These were on the trike when I bought it.
    Add your review:
    1977 ATC 90
    1983 ATC200E Big Red
    1985 Heald Super Bronc VT-10
    1999 Bayou 220
    2007 Polaris Outlaw 90
    Jul 2004
    Pride, Louisiana
    286
    The idea behind this thread was for anyone to post what tire they have, what they use it for, and how they like it.
    I know someone out there besides me has an opinion.
    1977 ATC 90
    1999 Bayou 220
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Best tire for a utility trike....is the ITP Mudlites.
    Good in mud, snow, sand,
    Had them on my 225.
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Kenda Klaws are a good tire, the work good in just about anything, mud, snow, MX, etc. Had em on my old 250R
    Maxxis Sur-Traks, good mud/snow tire, have them on my 350X and have yet to get stuck, but are TERRIBLE on the track.
    Wooly-Boogers are a awsome all around tire also.
    TF 07,08,09,10,11,12,13,14!
    Holeshot HD's - tough as nails!! Great for rocky hard terrain and hook up very well yet still spin on a 350X. May be too much tire for anything under 250CC's though as they are double the weight of a normal Holeshot.
    Holeshot XCR's - running them now on the 86 200X. Not sure if the sidewall will hold up as I haven't had enough testing time. They do hook up very well though.
    Plain Holeshot - another tire I had bead sealing problems (brand new rims!!) and I popped the sidewall on both of them. Will not buy again....
    Kenda Max front - seems like everyone is running them as a replacement for the stock front ATC tire. It holds up, seems fairly tough and doesn't wear too bad either.
    Old stock BANDIT XC's - MAN!! what a great tire this was!! Sadly it got discontinued and they offer the AT's now which seem to have bead leaks and a very chinsey sidewall. I won't buy them again.
    Turf Tamers - not for New England trails but a great all around tire.
    Avoid any and all cheap tires. I spend about 65-95$ per tire and I don't get flats or have other issues.
    Slime is great insurance for your beads seating well and without leaks.
    Jul 2004
    Pride, Louisiana
    286
    I got to ride a 250ES equipped with STU Mud Machines all around. Great loose terrain tire. Not so good up front.
    1977 ATC 90
    1999 Bayou 220
    Jul 2004
    Pride, Louisiana
    286
    Had a set of wooly boogers, Duro HF243 on my old 110 before the (ahem) trail pros. The Duro tires were great in everything I put them in. The ATC90 I helping a friend work on has the Duros on all 3 rims. I'll give a more exact review on them once it's running.
    1977 ATC 90
    1999 Bayou 220
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    619
    Dunlop KT335's. The stock tire on Raptors and Z400's. They are a real good all around tire. They get surprisingly good traction even in sand and snow. In fact, most winters now I don't even put my snow tires on any more. I thought they would wear pretty fast, being a stock tire, but they last a long time.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    MO dx's Avatar
    MO dx is offline Just Too Addicted Arm chair racerJust too addicted
    palmerton
    532
    I have had the wooly booger knock offs and the kenda scorpians on the back of my dx. For the type of riding I do mostly tight trails and snow I prefer the kendas. The woolys were heavy and really seemed to spin alot and get me stuck but were more stable. The scorpians are better for my riding just a little more tip over easy. I do want to try klaws next because of the flat tread for stability. On the frt I have a good yr terra tire its a 21 so it lowers the frt and its really heavy tends to keep the frt down and steers fine except in gooey mud where it packs up.
    Master of the DX and Pennsyltucky survivor ,08,09. Thats something to brag about
    Ontario, CANADA
    4,538
    Titan Fast trekkers- 18 in on 10 in rims
    PERFECT for the MX Track, thats where they feel at home.
    Yet to try them in sand, mud seems to pack up in them- Soulution stay over 3rd gear and stay pinned.
    Picture-
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Aug 2007
    Moab, UT
    1,807
    I run the 18" Kenda Klaw MXRs on the back of my R and they are stable and slide nicely. I've had them on the back of my 86 200X and they kicked azz on that thing too. They seem to work good all around and I've yet to get a flat. They are magic on the track. I'm also a firm believer in the Kenda Front Max, that's a great front tire, I actually prefer it over the stock style Dunlop. For ice racing the Cheng Shin flat profile knobby is the only way to go.
    Sorry, the first two pics are old. All three of my trikes are back at my shop where they are waiting for their new engines.
    Tilton Newfoundland
    612
    My favorite tires yet have to be the duro hf245. I found that they hook
    great in a straight line with the big gap between treads but the flat
    bars going across make it slide around turns great. Hade them on
    my 200x and m. They were 20x11x9
    On my 200s i had the Cheng shin knobby's. They were
    cheap and thats about it. I found they were to tall a profile for their
    width and any mud or snow would build up around them and make
    them as smooth as bolonga skins.They were 25x11x9
    1998 F150 reg cab
    Elan Ski-doo resto mod
    2012 Brute force 650
    98 ranger street truck project
    All my rigs are Loud and proud
    http://bikepics.com/members/mitchell-gosse/
    Jul 2006
    Picture-
    ME TO! AWESOME ALLAROUND TIRE, they work fair in sand as long as you keep the revs up starting to move after that they hook up great! you can reverse them and the center lug will act like a little mini paddle tire... but then it handles weird on hardpack
    I have 4 sets of treckers and many past ones! cant beat them!
    PA
    3,515
    the best MX tire i found yet is the razr mx
    holeshots are great but they are to soft and ware out way to fast and have tons of side bite....unlike the old holeshots.
    these slide great and have thick side walls and give great forward traction.
    WWW.HREATV.COM
    Pa.'s Highest City
    8,058
    Wink My .o2 cents...
    If your not on the track... these are about the best tires money can buy. I rode almost every weekend for the past several months and had zero issues. Traction is never a problem, and I can still get them to break loose when I'm feelin' brave.. 6ply and lightweight. Like mentioned above ITP mudlites but these are 20x11x9.
    Attached Thumbnails Attached Thumbnails 350x rebuild 106.jpg   350x rebuild 107.jpg
