Results 1 to 8 of 8
Thread: Anyone use Ipone 2stroke oil? vs Amsoil?
    roger86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2003
    Western New York (Buffalo)
    348
    Anyone use Ipone 2stroke oil?? I can get that locally here at an atv dealer...
    I've never heard of it before.... its SUPPOSED to be good... full synthetic
    Otherwise im gonna buy Amsoil online and wait...
    Roger
    1984 Honda ATC 250r
    Bored .020 over Wiseco, Answer silencer, fresh motor, New connecting rod and balanced crank, Boyesen 2 stage power reeds
    Dec 2005
    Wisconsin
    1,141
    a few years back on one of the sled forums I read up at there was a big post about oils and if I remember correctly some of the guy's swore by it. I would use it if you can get it. I think it smells good too. lol
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    SCRAMCHARGER318 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2008
    byron center
    154
    i can tell you i run amsoil in my trike and all my vehicle's and so does my father, it is very good stuff, recommend to anyone, when i first bought my 86 sx i switched it over almost immediately, and i noticed a little more power, but mainly a smoother clutch engagement, as well as the engine running quiter, i know your talkin about 2 strokes but amsoil in my opinion should be run in everthing period.
    May 2007
    Coshocton, Ohio
    1,815
    Amsoil is worth the wait.
    Appalachian American Racing
    the home of
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    i run KLOTZ. never used amsoil, but both are top quality oils. i would go with the oil that is readily availible that is good quality. Honda's HP2, Klotz, Amsoil are probably the 3 best oils out there.
    Heard good stuff about blue marble, but never tried it.
    Quote Originally Posted by SCRAMCHARGER318 View Post
    remember to watch amsoil or any synthetic in wet-clutch applications. the wrong stuff will cause MAJOR clutch slippage.
    What is this, the third two-stroke oil thread in 20 hours? Go to 2-stroke oil .com or something-
    Sep 2008
    byron center
    154
    amsoil makes a special motorcycle oil designed to run with both style clutches, it's about 8:50$ a quart but well worth it.
    300rman's Avatar
    Nov 2007
    toledo
    2,667
    i know they make it, i am just saying to make sure you dont dump the wrong stuff in there or you"ll be flushing the bottom end and replacing a clutch
