Thread: anyone ever replace neutral safety switch? 95 silverado
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    my truck didnt turn over this morning, i even tried my remote starter, (which i believe actuates the starter solenoid itself), and no go. turned the key off then on again and she fired up, did this one more time at work, then it was fine the rest of the night.
    so im guessing its gotta be the neutral safety switch since my remote starter didnt even work, since the ignition switch is out of that equation, but i guess it could probably be the solenoid too. i
    i was told the neutral safety switches are notorious for goin out in silverados though. so how do i remove the steering column and replace it? anyway to bypass it? anyway to narrow down the culprit 100%? btw its an auto trans.
    any help would be greatly appreciated as this is my only vehicle and i dont want to be left sitting anywhere.
    thanks,
    ty
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Jun 2006
    Willow, Alaska
    1,336
    Im not too sure if the steering columns are different for the slightly newer ones, but Im assuming its the same since its 88-98. Changing the switch is really easy, you dont even have to pull the column to do it. If you look under the dash where the column goes thru the firewall, a few inches up should be the switch held on with 2 screws. Take those 2 screws off, replace the switch, and your done.
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Ashland City, TN
    2,576
    The neutral safety switch is on the trans. The ignition switch is on the column actuated by a rod from the ignition tumbler...usually there's some kind of an adjustment on the switch, just drop the column down and adjust it until it works right.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    na
    5,702
    If this is a true 95 truck,and not a 94,the columns were redisgned.
    The 95 had a red hazard switch at the top of the column,and does not use a rod system to actuate the ignition switch.
    The 94 had the hazard switch at the lower right side of the column,and used the rod,and the neutral switch was on the cloumn.
    It makes a didifference as to the safety switch location.
    On the 95,it was located on the side of the trans.Most of the time,they glued the connectors in the switch and you need a heat gun to melt the glue so you can unplug it.
    Just becuase your remote start didnt work,does not mean it is the ignition switch or the nuetral switch.
    It could be the starter or the remote starter itself,messing with the factory security system on the 95 model.
    When it acts up,you need to take a test light,and test for voltage on the purple wire of the starter solenoid,while someone holds the key in the crank posistion.
    The light should light up.If it does,you need a starter...More common than either of the 2 switches on the Chevy's.
    Proudly NOT a member of
    "Team on the Teat"
    Central PA
    1,952
    hazard switch is on top, so the safety switch is on the trans? i have not had any probs with the remote start the 2 years ive owned it, but theres a switch under the dash to bypass it jus incase. it hasnt happened since, so your saying to just test for power comin out of the solenoid, and if not present try jumping the solenoid, then test ignition components if no go? can i just unhook the trans safety switch to bypass?
    PastRides
    SOON MY PRECIOUS!
