Hi everyone, I posted about this like 1 month ago, but nothing works, I have 2 ATC 110's 1981 and 1980, I need to adjust the pilot screw on them, they don't run right, i allready cleaned both carbs out, both tanks have no rust, one of them runs fine but idles high, then gets lower and lower then dies. the other one all and all doens't run like it used to, i had to mess with the factory adjustment becuase I cleaned the carb out and took the pilot screw off. The factory adjustment in my manual says 1 1/8 turns out, but it doens't run right with that setting, can someone please help! Thanks in advance!!!![]()
