Thread: Honda 250 Big Red rear on a 96 300 FourTrax
    svo58 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    clifton park,saratoga county,N.Y.
    166
    A friend of mine has a 96 Honda 300FourTrax with a bad gears in the rear ,it's the pinion gear .My quistion is will a 250 B.R. rear gears fit .It looks the same as my Big Red rear .Are the insides the same and interchangeable .Does anyone know if their is a difference between the two .Any help would be great ,thanks svo58
    84 big red 200es with speedo
    84 70cc ATC- new top end ,rear rack, head light and tail light
    85 250es big red
    85 250sx
    PA
    3,515
    i thought someone on here used the quad rear end on a big red and it made it longer?
    he was from alaska i think......anyway measure it up good and see if it is the same.
    WWW.HREATV.COM
    Jun 2003
    Anchorage/Homer, Alaska
    480
    I put a TRX250 swingarm and rear axle in my SX.
    I keep hearing the diffs between the SX, BR and TRX can be swapped, but the gear ratio is faster in the SX. Honda took the TRX 250 and made it into a 300, it's hard to know if the rear end gears stayed the same or not through the years. Only way to know for certain is if you had them laying next to eachother.
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    bad350's Avatar
    bad350 is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2008
    kentucky
    176
    You Can Swap Them But You Will Need To Build Some Brakets Yo Make It Work
