My 87 200X build
I bought this 200X about a month ago for 625 out the door from a dealer. It appear to be in great shape with normal original wear and tear. It has minimal dents in the tank, and the paint/pc is worn in key spots. Everything works on it. The head light had a busted cover. The fork boots are ripped, Thus causing the fork seals to fail. I rode it for about 2 weeks pretty hard, Then the clutch started slipping. I decided if its going to be down for the clutch, I should hog wild it. There the pix of my buddy and his kid on it at a motor cross practice track.
I have put it down for the start of the build.
I have gotten the following:
New red front and rear fenders as well and new red tank shrouds.
Athena fork seals
-1 tooth front sprocket
Black engine paint
LTZ400 front brake res.
IMS folding shifter
Temp gauge
Raptor 660R rear shocks
Head light cover
Custom SS dash plate
PRM wide rear grab bar
Long Horn fat bars with adapter
ASV shorty C5 clutch
Tusk hand guards
Douglas blue label 10" rear rims
20" Kenda Klaw XCR or 20" Kenda Fast Trekkers (havent decided what pair to run yet)
Parking brake block off
Black fork boots
Red valve stem caps
Spike valve stem caps for the forks
Clutch kit
Rear shock cover
Plan to order soon:
Red chain
Syko tank
23.5 Kenda Front Max
Seat cover (black)
Rear wheel spacers
ASK shorty black C5 front brake lever
ASV dust cover
PC work
Spider or Tag grips
Nerfs of some sort
Maybe some Trail Tech lights
Future plans:
LTZ400 pegs with maximizer from Pro Armor
Full exhaust
Cam (any advice)
ITP C-series rims
Bigger carb (need advice)
EHS Racing air box lid
XR200 CDI box
Attack grahics
Rear # plate
Iradium plug (spelling?)
And last but not least respect at the MX track
Ill keep you posted as I go. If you have any advice or opinions please let the flow. I will also be needing a fork cap for it if anyone happens to have one.
1987 Honda 200X 90% way through frame up.
1987 CR500R Motor, Soon to be a 540 ATC motor
1986 250R frame, For now
2008 Honda 700XX
2004 KFX700 Torque monster!
2011 Can-Am Commander 1000X
Looking for misc Liquid R parts
