Been trying to fix this problem for over 2 years. gave up on it about a year ago.
story:
Took the ATC to a local shop to get the top end rebuilt, it took them months and months to do, i finally got it back and it had a very loud annoying constant ticking noise. I didn't care to have them fix it, i just wanted my ATC back. Shop went out of business a month later.
So, I let it sit for awhile then tried to start it, was leaking gas and in need of a carb rebuild. Gave the carb cleaning a shot....didnt work. Doesn't get gas at all. If you spray some starter fluid in there it'll run until the fluid runs out, then die.
I recently purchased a carb rebuild kit, and I'm going to attempt this again today, and see if i can get it running again.
problem is, i still have that ticking problem which many have guessed to be ba a valve in need of adjustment.
So.... how do I adjust the valve?
and could a bad valve be the ticking problem?
i suppose i need feeler gages? where do I get those?
A person of my expertise should probably be paying a shop to have this done, problem with that is NO shop around here will even touch an ATC.
I have been looking for over a year.
theres a large off-road shop that will do it, they want $100 for the estimate, and $150 an hour labor. and estimated me at 4 hours for the valve adjust, and 3 for the carb rebuild. + parts
I'm not looking to spend $1,100+ on a valve adjust and a carb rebuild.
I could buy a much much much nicer bike for that much money.
