VITO's IS JUNK, You shouldn't talk about things you know nothing of dude!
Vito's does NON of thier own
parts, they are built by the LOWEST BIDDER, yes, the lowest bidder, and then sold with phony HP. gains.
Be my guest if you are to stupid to do ANY research and want shabby
parts on your ride! Vito's does not do any dyno runs on thier
parts, they are just built and sold, try calling and asking for a tech to help you and you will see the light!
L.A. Sleeve builds ALL thier own stuff and they do a GREAT job. They ARE the best running 240 out there but the 270's will kill them!
Milled head (.070), PORT, (I mean raise the exhaust 2mm, widen it 1mm, raise all the transfer ports a mm at least, widen everthing you can and SMOOTH the exhaust port, glass beading gives the best atomization for the intake and transfer ports,) put a 38 flat on her, Reeds are about the same either way so no fuss there, and CPI has a KILLER blaster pipe if you want something with a little more rev than the toomey! You will have a hell of a runner at 200cc still. If you want to go big, skip the 240's and go 270 on alky!
