Thought I would share with you guys.
Had it out last wkend and finally got it tuned. It's an 85x78 running a 6 mil hot rod crank.
Home of the NW fastest 250R's
I like it.
where is your gas tank filter!
what swingarm?
'08 KTM 525EXC
'07 CBR 1000RR
'07 800 Arctic Cat 154"
'85 ATC 250R
'84 ATC 250R
'84 ATC 200X
'71 CT90 K3
filter? That's funny....lol
bad a** nice work on that trike
beeeaast..... killer trick 250R, mad work!!!!!!!!!!
absolutely goergous!!! good i need to get me a liquid r.
Looks good dude.. Nice job
DAM! That machine looks real nice!!
Well, how's the outcome? Did you have a BIG combo on before. If so, is this far superior? I think it looks fantastic, and different from the norm.
<--- enough said!! very nice
pfff looks like junk, I herd those things are barely runnin with piped fo fiddies.
Looks great, How does It run???
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
I had an ESR 370 that made 70 rwhp on LRD's dyno. This is a 442.6cc that pulls quite a bit harder up top. Out of the whole the torque is "seat of the pants" noticible when I launch. Only issue is, I have already burned up a brand new clutch, so a lockout is on order, along with an 1-4 override. The 370 cylinder is 2 lbs heavier then the Puma too
