I have a 1985 Honda BR 250es. When decelerating in gear I am getting "popping" out the exhaust, and very occaisonally a larger backfire when in gear with no throttle, such as idling down a steep grade. Any common reasons for this? Fixes?
1985 Honda Big Red 250ES
27x12-10 Mud Bug rear tires on ITP aluminum rims
27x10-12 Mudlite on front
adjust your mixture screw
Rides
85 ATC350X
85 ATC200X
Incorrect fuel/air mixture. Sounds like its running a little rich.
You will have to play with your carb and see if you can fine tune it a little.
A few wheelers, + an
'73 Honda 49cc Mini Trail
'85 200 Big WHEEL
"Despite the cost of living, its still popular."
Also, you might have a slight exhaust leak that will tend to draw in fresh air into the exhaust when decelerating and will cause this problem. Had it happen to mine once.
this should give u a pretty good understanding of carbs..
http://www.3wheelerworldforums.com/s...ad.php?t=55086
My freind put a aftermarket on his BR and had a leak in the same spot as yours and after we repaired the leak it never backfired again, so I'm almost positive that when you repair this leak you will stop the backfiring..
1987 200x
1987 Big Red
1986 250R
1986 Tecate
1986 Tri-Z 250
1986 Big Red
1985 Polaris Scrambler
1985 KLT 160
1985 Tiger 250
1985 Big Red
1985 Big Red
1985 250sx
1985 70
1985 225 DX
1982 185s
1983 110{Red}
1983 110{Blue}
(2) 1977 ATC 90
1971 US90 Red
1971 US90 Parrot Green
1971 US90 Blue
