Personlly I would use the kit or at least a new float needle I rebuild carbs all day long
and pretty lucky with bowl gaskets but I would do a leak test before re install If you want it done right get a kit and if you remove the fuel air screw cout how many turns
to lightly seat it before removal so you get back in at the right setting I usually just dont even bother with the fuel air screw and leave it in but that only helps if no one has messed with it previously.
83 YTM 200,84 200X,,85 350X basket case,86 350X parts trike,86 350Xroller needs top end, 86 250SX,
