Results 1 to 15 of 16
Thread: front end wobble
    Feb 2008
    san clemente CA
    15
    front end wobble
    ok, got an 85 250r when im driving straight my frond end wobbles almost like im turning the handlebars back and forth. It does it real bad on pavement but i can tell it does it on dirt as well. Now ive checked that my front rim isnt bent and everything looks good no tilt or lean. Any suggestions would be helpfull...thanks!
    Apr 2007
    Springfield, PA
    889
    same thing happens with my X, and only on pavement. only thing i can think of is the pavement pushes the wheel to one side, then pulls it back straight and repeats??? only does it when i take my hands off the handlebars thought.
    My Rides
    1983 ATC200 - U-Haul edition - great mudder - SOLD
    1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
    1987 Suzuki DR200
    199? Go-ped Sport
    boosted96cobra's Avatar
    boosted96cobra is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    n utah
    279
    The rear wheels or axle or hubs are bent. My 200x was horrible, new wheels it perfect now.
    http://i291.photobucket.com/albums/ll292/sagep11/IMAG0069-1.jpg
    84 tri-zinger
    85 ATC 250r
    86 TRX 250r
    85 ATC 350x
    86 ATC 200x
    Apr 2007
    Springfield, PA
    889
    to the best of my knowledge, nothings bent on my rear. when i do a wheelie it does not vibrate or shake, its very smooth, so???
    My Rides
    1987 Suzuki DR200
    199? Go-ped Sport
    Feb 2008
    san clemente CA
    15
    im not sure that the back rims/ hubs being a little tweaked would make the front end wobble. Seems like it would make the back end shake.
    Dec 2006
    St. John's Newfoundland
    1,587
    Bad tire?? I had that happen before. On the rear ofcourse. When we sized up the brand new tires, one was like an egg. Bearings?
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    I've owned allot of ATC's and quite a few have "wheel wobble" and it's one thing I could never figure out....
    Feb 2008
    san clemente CA
    15
    Quote Originally Posted by Brockey View Post
    The front tire is practically brand new, straight rim. As for the bearings i stood the trike up and spun the front wheel, no wobble and i tried wiggling the tire and there is no slop in the bearings. Someone said something about the tripleclamp not being tightened down right would cause wobble?
    Sep 2005
    MICHIGAN
    2,027
    bent forks?
    Mine does it too.
    86 T3
    84 T3
    86 KX250
    Feb 2008
    san clemente CA
    15
    yea bent forks would prolly do it, i dont think mine are but who knows. I wonder if you diddent have the exact same preasure in each fork that would make one longer than the other causing wobble?
    Aug 2007
    Moab, UT
    1,807
    My 200R had front end wobble going down the pavement with it's stock Ohtsu front tire. I switched to a Kenda front max, and the wobble was gone. I got to looking at the old front tire and found it had a very strange wear pattern, almost like it was cupping. So, quite possibly the tire is the culprit. Loose steering stem will cause death wobble also. Some tires don't do well on pavement, especially when your only running 3.5 psi or a little less.
    Utah
    644
    It is natural for a 3 wheeler to start to wobble back and forth when riding on pavement beacause of the solid rear axle. Each tire tries to get ahead of the other tire. However it should only do it when you let go of the handlebars. If it is doing it when you are holding onto the bars them something is wrong.
    Possible Problems. (Not inclusive)
    rear tires not inflated equally or stretched equally
    rear bearings gone
    swinger bearings gone
    front bearings gone
    steering stem bearings gone
    bent front axle
    bent rear axle
    bent frame
    bent hubs
    bent wheels
    bent swinger
    worn swinger bolt
    bent spacers
    missing spacers?
    roads are crowned, so driving it will naturally pull you to the side. Again, it will do it because of the live axle, but shouldn't be noticable if you are hanging onto the bars......
    Does it change with speed, braking, acceleration, turning?? does shifting your weight onto the front or back, or side to side, make any difference??
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
    Michigan
    1,144
    I had the same problem on my Big Red when I put it back together after restoration. I finally figured out that the rear tire pressure was not equal. I finally got it straighten out. Get a GOOD tire pressure gauge.
    Sep 2005
    Lipetsk, Russia
    2,824
    Sounds like the front bearings are going out. It will cause the wheel to see-saw back and forth as it follows it's own path on the dirt, and those little jerks will be transmitted to the bars. Try to jack up the trike and take the front tire, and move it side to side on the axle (the way the tire would turn if you turned the bars, but keep them straight, if that's not too confusing to understand). If there's any play, you need new bearings or possibly a new front axle.
    Feb 2008
    san clemente CA
    15
    Quote Originally Posted by RedRider_AK View Post
    already checked for front end play, there isnt any. I need new back tires, no I REALLY need new back tires. lol so thats probably my problem, thanks guys!
