It wont run because a broken cam chain... It worth maybe 75-100 to me.
Whos to say it doesn't need new valves, valve guides, piston, timing chain, rockers, or even a cam? timing chains(cam chain) don't go out alone normaly. If that broke, the engine probably worn out pretty bad. Id take the cover off the side of the head and look at the cam chain, it might not be broken.
It might need an engine.
