View Poll Results: What does "Cold Natured" mean to you?
Voters
14. You may not vote on this poll
  • Its just cold natured is all.
    7 50.00%
  • Carb needs work or its some other problem.
    3 21.43%
  • Old age.
    1 7.14%
  • Other? Explain.
    3 21.43%
Results 1 to 10 of 10
Thread: "Cold Natured"
    jmsmilin's Avatar
    jmsmilin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    "Cold Natured"
    I hear this term a lot. Heard it twice just recently on some bikes Im looking at. My inlaw calls his 4 wheeler that, and I have probably used it once or twice myself. But what the hell does it mean, and what does it mean to you? Why wont they start easy like they should-whats the real issue?
    RIDES:
    Current OG rides:
    ~1993 300EX 1 owner (just sold)
    ~1993 TRX90 matches the 300
    ~1996 Z50R the FIDDY
    ~1992 YSR50 (sold)
    ~ATC 70 (w/suspension), ATC 185S (w/susp), 250SX, 350X, etc, etc, ALL SOLD!
    WTB: small machines - ATC70s w/ suspension, TRX90, z50, CRF/XR70/110, CT70, CT90, SL70 etc.
    Favorite riding spots:
    1. Twin Buttes, San Angelo TX
    2. Turkey Bay, LBL KY & Linton Beach in Bumpus Mills
    3. Sunnyside ATV, Wrens GA
    PA
    3,515
    its the same thing as a bike thats cold blooded.... like a snake i guess
    they dont like the cold weather....... wont run right or start easy
    WWW.HREATV.COM
    cold blooded ....dont start easy...
    jmsmilin's Avatar
    right, but the question is why wont it start easy...
    RIDES:
    Current OG rides:
    ~1992 YSR50 (sold)
    PA
    3,515
    well, cold weather will lean out your carb so if you are on the lean side before cold weather comes it will be real lean and hard to start.
    richen up the air screw and pilot some and i bet it will start easyer
    WWW.HREATV.COM
    Minnesota
    451
    Well, "usually" larger displacement will be more "cold blooded" in my experience. My raptor is very "cold blooded." It doesnt start to hard but needs to run on full choke for quite a while before you can even think about driving it.
    Some of this could be jetting. Im sure if you wanted, going with a little bigger main & pilot in cold weather would help.
    It could also be other problems. I have an old 600 polaris indy tipple which is the most cold blooded thing ever. Under 25 degrees it wont pull fuel. There are other problems their, something with vacuum lines/fuel pump, ect. Im not exactly sure yet.
    OR, It could be poor design as in the case of the early 85 250es Bigreds. The carbs didnt have a proper cold start circuit, too small pilot, venting issues (hence the service bulletin)
    Now, the easiest cold starting rig Ive ever worked on was a 92 honda 300. The carb has a little primer and that thing would start right up, warm for a few seconds, and drive. Ive even thought about putting one of those carbs on my 250 just for that fact.
    1985 Honda 250es "Big Red" 1984 Honda 200s (Sold)
    1984 Honda 125m 1986 Honda 200x (new project)
    2003 Raptor 660 1978 Suzuki GS1000
    Jul 2006
    western ny
    3,366
    my modded 200s motor is cold hearted sob. wont start worth a crap but once its warmed up it runes like no tomorrow.
    GIT IT RAAAGGGGG !!!!
    Nov 2007
    tx/damon u.s.a
    42
    Quote Originally Posted by BigReds Forever View Post
    i have one of those hard to start early 85 250 es whats bulletin or fix for that
    Oct 2007
    Grosse Tete, LA
    3,440
    well a 300 honda is a different beast all it's own, there is no such thing as cold natured for one of those...best utility bike honda ever built, best utility bike honda WILL ever build.
    one tap of the starter and that bike is running...no matter what.
    Utah
    644
    I had always thought that "cold natured" meant that it ran super well in the cold, and that "cold blooded" meant it did not like the cold. I can see how everyone compares it to a cold-blooded creature such as a snake, meaning that it never really quite gets up-to-snuff in cold weather. However, my R is the exact opposite. The colder the air, the better my R runs, with a very noticable difference. So going by my own meaning, I would consider mine "cold natured", but NOT "cold-blooded". But according to everyone else has commented so far, then mine should be "hot natured". Just seams a little backwards to me.
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
