Results 1 to 15 of 23
Thread: will a kfx/ltr 400 carb work on my 350x?
    Jul 2006
    Question will a kfx/ltr 400 carb work on my 350x?
    yep need to know I got one in a trade, I had to order a choke plunger, will it work on the 350x? would it be an upgrade like the 400ex carb?
    Apr 2007
    HUH? sycolincoln asking a question I thought you knew everything Alan Just kidding you dude the only thing I might worry about is if it has any kind of electronics hooked up to it like TPS and so on, I don't get into the new 4 pokes so I don't know crap about the carb's they have.
    Airfoolers RULE!!!
    Jul 2006
    hey what can I say?? im not a 4 stroke guy!! no electrics, and someone is going to have to explain to me how the slide works!! its not hooked to anything other than a diaphram at the top of the carb, the throttle cable only operates the buerfly valve on this carb, does this carb have to have a vacume assist hookup? and how would I go about doing this? is it even worth it? lol
    Jul 2006
    apparently it does use a vacum assist on it, there is a line that feeds directly into the top of the carb into the slide diaphram, how would I hook this up, put a hole and a fitting into my intake boot? man.......4 strokes suck! this is all so overkill
    Jul 2006
    anyone? come on guys!
    Jackson MI
    1,688
    If I was you I would look for a FCR from a crf450. You will probly have to mess with the suzuki carb a while, where the FCR Is alot easier to tune. The FCR Is alot like a 2 stroke carb adjustment wise, except Is has a fuel screw Instead of a air screw. It also has an accelerator pump. That Is just my opinion. I'm sure you can make the zuk carb work, either way let us know how you make out.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Jul 2006
    well thats what I want to know can I make it work? I dont want to go hackin up my only running ride ride now to find out, It also has a full moose stage 2 jet kit with it so its very tunable, also wouldnt that 450 carb be a bit strong for a stock 350?, the main thing here, is that im asking how does the slide work? its not like the stock 350x carb with the linkage to open it up theres nothing like that, it appears to be vaccum operated and I dont know where that needs to be hooked up.
    Jackson MI
    1,688
    Since you have It, put It on and see what happens. The vacume from the engine pulling air Is what pulls the slide open. It might work great. Can you make the throttle cable fit the honda thumb throttle? When I put a 400ex carb on my 350x I had to adjust the accelerator pump so It would'nt stumble just off Idle. The 350x engine wanted a shot earlier than the 400ex. See If the suzuki carb has a adjustment for the acc pump If It does, get an Idea of how to adjust It & let er rip. As long as you know what adjustments to make to tune It In, I'm sure you can make It work. Just remember when adjusting the Pilot screw that you are adjusting fuel, not air like on a 2 stroke carb.
    One pointer that I always try to pass on Is. If the air/fuel screw Is In front of the slide you're adjusting fuel, In Is less- out Is more. If the A/F screw Is behind the slide you're adjusting air & In Is less- out Is more.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Jul 2006
    I will give it a shot tomoorow, but I dont see where the vacume of the motor will pull the slide open but WTH I will try.
    Aug 2006
    new hampshire
    914
    one line goes to a vacume operated fuel petcock. that will need to be blocked off.
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Jul 2006
    ok I think I know of that line, but at the top of the carb in the diaphram that operates the slide there is another inlet with a line hooked up to it.
    Aug 2006
    new hampshire
    914
    one of them is a vent. it is fairly large, and i think on the left side.. the vacume line for the fuel petcock is smaller in diameter...they have natural bends in them. thew vent goes down the vacume line goes up. if you need some more help i can give more detail monday when i grab the service manuel. i adjusted my friends valves on an 03 z 400 and jetted the carb on thursday and he has my manuel.
    1982 ATC 70
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2020 CF Moto 600
    Feb 2006
    Texas
    738
    Syko, install the carb and try it. I'm pretty sure it will work. It did on my DS 650 with nothing hoked up to it. The hose that worked the diaphram on the DS ran from the airbox and when it was removed it worked without doing anything else at all. The carb you are working with is the same, only smaller. It will pro'lly need adjustment tho.
    Hope this helps.
    TORKER.
    THOSE WHO SAY IT CANNOT BE DONE, SHOULD NOT GET IN THE WAY OF THOSE BUSY DOING IT...
    Jul 2006
    Quote Originally Posted by badasskfx View Post
    thanx!!! thats what I needed but still monday let me now the exact rouging and placement of those lines you are talking about, and TORKER I wll do as you and a few others have sugested just put the damn thing on and see if it works.
    DIGGER DOG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    in the sticks s.w ga
    446
    the suzuki carb you have is called a constant velocity it works via air pressure flowing
    through the venturi passing lift holes in the slide causing it to rise also pressure at the top of diaphraghm.
    the z 400 and like engines i think are bigger air pumps than the X beacuse of the shorter stroke way more of a revver than the X that = massive air flow that I think the X wont be able to match.
    I would try to find a mechanical slide carb for it
    I may have an oem 350x carb at work I could part with but it may need a rebuild kit
    Drop by the shop tuesday if interested its Honda,Yamaha, Kawasaki of Albany Ga.
    Ask to see Steve. By the way Ill just give you the carb.
    83 YTM 200,84 200X,,85 350X basket case,86 350X parts trike,86 350Xroller needs top end, 86 250SX,
