Thread: Can K&N filter oil cause engine to smoke ?
    Sep 2007
    Quebec, Canada
    9
    Hi There, I recently put a K&N oil filter on my 84 200M and noticed that the engine blows smoke at start up. I removed the air filter and there was a good blob of the red oil that fell on my finger, indicating to me that I might have over-oiled it and this was being sucked up into the motor and pushed through as smoke. This only started after I installed the K&N, which leads me to hope this is the problem and not the rings etc...
    Anyone ever experience something similar ?
    Thanks in advance
    Jun 2006
    Ohio
    2,294
    K&N filters come way over oiled from the factory.I always clean them off once,and lightly re-oil them.
    1981 ATC 70
    1978 ATC 90
    1985 ATC 250R
    www.cosmicquads.com
    Feb 2006
    Central Florida
    1,090
    I have had several instances where the only explanation for smoke was the oil on the filter
    quiet people seem intelligent
    Aug 2006
    new hampshire
    914
    after a good ride the excess oil will be gone. if your smoking on cold start up evrey time its more then likely another cause.when i clean my k and n it runs kind of crappy for a few minutes then it comes right out of it on my r.
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
