Results 1 to 15 of 15
Thread: Krylon fusion paint on fork boots ?
    Jan 2005
    Slatington PA
    4,372
    Think it would work, adhere to the rubber and also would it start cracking from the compression and expansion of boot?
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    will NOT work. will flake off faster than you can spray it on.
    you need some VINYL paint for that
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    little 6.5 HP minibike (Wicked Quick)
    2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
    1969 Broncco TX-6 (yes its spelled correctly)
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
    I want to come to Trikefest 08!
    Jul 2006
    western ny
    3,366
    Quote Originally Posted by Nightbiker07 View Post
    i love the stuff and use it allot but i agree.
    GIT IT RAAAGGGGG !!!!
    Pa.'s Highest City
    8,058
    What color you have in mind. I'm thinking you want the stock boots though correct?
    Here's some diffrent colors but sorry.. their fresh outta pink!
    http://cgi.ebay.com/ebaymotors/Motor...spagenameZWDVW
    Jan 2005
    Slatington PA
    4,372
    Did you ever try the vinyl on boots Nightbiker ?
    Most likely I'd be the gunie pig !
    Sep 2007
    Toledo, Ohio
    382
    no, but the boots should be some kind of vinyl composite, and vinyl paint sounds about right.
    other than getting new boots, vinyl paint is your best bet.
    i believe that, as long as the boots are made out of a material the paint is designed for, the vinyl paint will work, no prob. ]]but fusion will most definitely not work. it has different adhesion properties, and is SLIGHTLY more flexible then regular bugbomb paint, but is for plastics mainly due to the adhesion. will crack and flake and just piss you off.
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    Jan 2005
    Slatington PA
    4,372
    You notice in that video of the different boots that some have a smaller heigth on the very bottoms, mine (stock ones) are the longer heigth and I want the royal blue which has the longer heigth.
    Utah
    644
    I tried the Krylon Fusion Paint on one of my faded red boots. It stuck and did not and still has not flaked off, but it never dryed, and was sticky for about 3 weeks afterwords. Did not coat evenly or smoothly, and the color did not turn out like it was supposed too.
    I like the fusion paint, but sadly it does not work on fork boots.
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
    havelock nc
    134
    i painted my rear fender with it. looked fairly good. wait the 7 days before touching it again so it would cure properly well when i put my decal on the left side the damn plastic your pull from the decal when its set in place, ripped all the paint off from around the decal. BS
    Jan 2005
    Slatington PA
    4,372
    That place has their dimensions (they don't notice that???) saying two different sizes, one in pic below and other here ......
    16" Fully Extended (mine are 13" but that certainly won't matter they never go fully extended anyway)
    11" Relaxed (close enough)
    4" Collapsed (right on)
    1 1/4" Top inside diameter (right on)
    2" Bottom inside diameter (right on)
    If it's the above dimensions they will fit, in pic, won't fit, too large of diameter.
    I'll email them and tell them to WAKE UP !!!
    They look like the same ones as here although this dude has the same ones on at two different prices, what's with these fork boot guys?
    Hmmm, let me see now, which ones should I take I got them, the 9.95 jobs, they should work fine. Hopefully the dude will post my R in his adds once it's done, because I asked him to
    http://cgi.ebay.com/ebaymotors/Honda...QQcmdZViewItem
    Jan 2005
    Slatington PA
    4,372
    Dang, I just noticed the boots on my 85 SX looks identical (I measured tube diameter also) to the 84 R so I could of got blue OEM 85 SX jobs for them!
    Oh well, those that I got should work fine.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Rustytinhorn View Post
    Why don't you give nightbiker's #6 post suggestion a try ?
    Manheim, PA
    5,816
    huffa,
    you should just get some dirtbike ones. i got a blue set on my 200x front end. they look way better then old trike ones. they kinda look like the 350X ones, the cords are closers together. dennis kirk sells them in all kinds of colors...black too.
    Feb 2006
    Central Florida
    1,090
    oldskool - you have a link?
    I have been thinking about the cloth type covers.. but might discard that thought if I could find some boots i liked. The ones I got off of ebay have fat ribs and an off color
    quiet people seem intelligent
    Manheim, PA
    5,816
    the far ribs look like crap...also make it look like ya have non shock travel
    denniskirk.com
    they are daystar 69 series. i have these blue ones, but from dirt and stuff that turned darker blue. they make all the cool colors.
