Yes I used a 07 TRX swingarm.
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
Looking good Jason!......
1986 ATC 70
1985 ATC 250R - Hondaline Special
1985 ATC 250R - Flat Track 'Privateer'
1985 ATC 250R - HRC 450RR.
1986 ATC 250R - HRC Flat Track.
1998 Honda Laegers TRX 250R (CT 350 PV) N/F cr500 link.
1998 Honda Laegers TRX 250R (Sparks 330) N/F cr500 link.
1999 Honda Laegers TRX 250R (Sparks 330) N/F cr500 link.
2016 Yamaha Laeger's Banshee YFZ 350 (DRI 350) N/F cr500 link.
Thanks Gordon, I'm finally getting somewhere with It![]()
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
Finally got It off the bench. Now I can start fitting the subframe & shrouds![]()
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
Dude Jason...leave it that way and finish it. TRIALS TRIKE! Haha it'd be sweet!
1986 ATC 70
Billy, It does look like a Trials bike for sure. I'm gettin to old to have no seat though![]()
Gordon, I need to ride It before I decide to run the axle leading or trailing. The bike frame has alot of rake built Into It. That rake makes the wheel base longer than I like. I have learned the hard way with the other bikes I've built that with the extra rake the trailing axle should work out best, I hopeI have also learned that the center to center measurement of the steering stem and fork tubes In the triples affects the rake more than one would Imagine. I will know for sure once the first ride Is possable.
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
Jason, looking real good. Do I see the footpegs I sent? If so, did they bolt right up? Hoped you could make use of some of the stuff. More pics brutha.
Yes Speedbump they are your footpegs. I had to grind them thinner (where the pin goes through) to make them fit the 450 frame. The pegs need to go way forward though.
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
A couple updated Pic's. The gas tank Is made from cardboard don't laugh, and no It won't hold gas![]()
I hope to have the aluminum tank done before my rear fenders get here on Wednesday.
83 ATC 70.
83 Tri zinger
ATC450AF
86 310-R Drag racer
Sickkkkkkkk
Need Any 350x Parts? Lol
looks bad ass Jason! Awesome work as always.
that is one beautiful piece of machinery right there
1985 Honda ATC200S
1994 Kawasaki Eliminator EL250
Wow,,,,looks excellent Jason, can't wait to see the rear plastics fitted.
1986 ATC 70
holy cow man, that thing is turning out absolutely awesome!!!!
