Page 14 of 16 FirstFirst ... 4 12 13 14 15 16 LastLast
Results 196 to 210 of 226
Thread: Aluminum 450r 3 wheeler.
  1. #196
    Jackson MI
    1,688
    Yes that Is correct!!
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
  2. #197
    Cincinnati, OH
    3,289
    thanks a lot man! but lets just say i needed to tilt the frame like an inch how would you do it without moving the pivot area of the swinger? move the upper shock mount down??
    "MR.Clean"
  3. #198
    Jackson MI
    1,688
    Quote
    Yes, set your rake where you want It, then figure out where to mount the top of the rear shock. Do everything temporary at frist, set the bike down and make sure your close before final welding / mounting Is done. Remember the more the rear of the bike sag's, the more rake the front end will have. So Everything needs to be right before you weld. Thats the exact mistake I made, I was set on running the front axle trailing, and finish welded the rear suspension. The easiest way for me to correct the problem I caused was to mod the rake at the steering head.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
  4. #199
    Apr 2008
    Kalamazoo, Michigan
    814
    I think the only problem was a little bit of MagicJames, haha
    Maybe I'll brave up again and try to ride the beast once more, Of course if that's ok with your son, LOL
    He was more sad than I was and it cost me a whole 2 weeks pay!!
    Leave feedback for me here : [Please Don't start another thread again!]
    http://www.3wheelerworld.com/showthr...for-MagicJames
    Current :
    86 250SX
    86 350X
    86 250R Project
    Owned and Sold
    85 250R
    2 ATC70's 84 and 79
  5. #200
    Cincinnati, OH
    3,289
    come on magic what happen!
    "MR.Clean"
  6. #201
    Jackson MI
    1,688
    Well you didn't work ANY magic on that did ya? I don't think my boy or I will let that happen again
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
  7. #202
    Cincinnati, OH
    3,289
    jason to get the rake does it have to be crf450 frame only or is there othe models that got the rake change in 05? cr frames? or what?
    "MR.Clean"
  8. #203
    Jackson MI
    1,688
    I never really checked Into other model's. A search on google will get all the Info you need. I searched for CRF450r spec's, then picked a year
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
  9. #204
    TexFest's Avatar
    TexFest is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    U.S.
    339
    Jason since you have a rear kick, and I notice you installed a different kicker, does your foot ever hit the fender when you start it?
    TPC 450R
  10. #205
    Jackson MI
    1,688
    Quote Originally Posted by TexFest View Post
    You need to position your foot correctly on the kicker. I don't want to cut my rear fenders, so I use a short YZ 125 kicker. It does a Fine job once you know the drill!!
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
  11. #206
    I just wanna say again, AWESOME INGENUITY!! and the fact that you share these findings with ALL of us tells me that you enjoy it and it doesn't have to be a "secret!!"
    Every build teaches you something else............. And you share it
    Nice work Jason, but I bet you've heard that enough!
  12. #207
    Springfield Mo
    3,309
    Quote Originally Posted by MagicJames View Post
    Fill us in! What happened????
    Jason: Awesome Build. I just stumbled upon this thread. I always wondered where this trike cam from in your pic!!
    Have you ever thought about building a trike out of a Honda TRX 90? I know it doesn't provide a big boy trike, but it could give the younger guys something to ride. Would it even be worth it to do a build with a TRX90? I have had one in my garage for 4 years. I just can't bring myself to sell it. It runs fine and everything.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
  13. #208
    Mar 2004
    99
    Read the entire thread and love it, I didnt see if you ever mentioned how much rake degree change from 05 and newer frame vs older frame?
    Also side note do you know if the TRX quad engine bolts into the Bike frame??
    I want to build another hyrbrid, 05 and newer based CRF450X, but unsure if gonna buy bike to start with or maybe a quad and then buy the bike parts, and use quad engine? Also mine will be street legal like my WR was. Keep up the great work!
    Can I get a template on those tripple clamps
  14. #209
    He did in fact mention that the newer frames had a better rake to deal ( which may mean - lower the shock mount, set up the ride height and your good); But I believe the newer frames were allot more expensive than the nice earlier year (maybe 04) frame he picked up...........
  15. #210
    Nov 2010
    Somerset nj
    108
    WHo built your ytz 450 that thing is ultra sweet!
