I need some expert advice. I took my 1984 200s out for its first real test this last weekend. It performed flawlessly -UNTIL I had it wound out in fifth gear at full throttle. It suddenly began to spit and sputter and seemed to lose all power. I was able to limp back to camp under its own power. Since this event, the bike idles just fine and will even rev fairly well in neutral, but struggles to run when in gear.
So far, I have:
* Replaced the plug - it was very dark and soot covered. Unfortunately, this produced no change in perfomance.
* Tried to check the resistance of the primary and secondary coil. My Craftsman multi-meter doesn't seem to be sensitive enough to get an accurate reading. I get an infinite result on the secondary which obviously is impossible since it does run.
* Tried to check the resistance of the CDI, but again the multimeter issue yields some pretty questionable results.
* Cleaned the fuel screen. No change in performance
* Checked and adjusted the gap of the pulse generator (was approx. .019" should be .012" - .016"). No change in performance.
Anyone have thoughts of what to try next? I would appreciate any suggestions.
					 Help with 200s - Performance suddenly went to crap.
					 to the board too!
 to the board too!
				 let us know how it turns out
