does anybody know if a 81-82 atc 250r motor will fit a 83 250r? Or will just the bottom end work.
my buddy just got a 83 with no fifth gear. i found a couple deals on 82 motors on ebay.
thank
thank
JASON LISKEY
2 = 86 atc 350x's
86 atc 250r
1985 350x
1985 350x
1985 250r
200 auto x
1984 250r
1982 250r
85 Tecate
86 Tri Z
85 TRI Z
98Wolverine
99TRX 300
Yes it will fit like a glove. 81-84 are the same except the drive+suspension.
I have a 83-84 motor in my 82 250r. The only thing you notice from the out side is the later ones are black and not red. I beleive the 83-84's have bigger porting.
Great news!! They've been waiting 2 years for this info![]()
Time for a bong load!
I need to talk to someone who has built a 1984 250R. I had to do so much research just to figure out that my front forks are from a 85'. The bike is a 1982. ??
They need to remanufacture some DG COOL heads for the old school trikes!!
Can't they just make a mold or something?
you could have to make a cast, the problem is you have to get a few in on it, and when I say few I mean around 50 units. I have looked into doing it through my own company and its going to be pretty expensive to do...
86 ATC 500R the duner..
85 ATC 500R...the not quite finished faster duner
1985 ATC 250R Bone stock!!
1985 ATC250R mx/duner
1986 TRX370R MX/Duner
94 Banshee 400PV Cheetah 105RWHP
shortline10's I can tell that you ride your trike because your suspension in the rear is low for better control. Low in the back high in the front. I think the 86' R is too tall.
TRUE. Damn I love those things. I would probably buy a trike just because it's on there!!
I heard In the grapevine that HONDA used to have a water cooled head for the 81-84 250R's. That would be nice.
Post a bunch of pics of your bike.I want to see it closer with the water cooled parts installed.Thanks
