Results 1 to 9 of 9
Thread: YTM idleing help
    Sep 2005
    central Illinois
    651
    YTM idleing help
    Hey guys, got a problem with my 1983 YTM200. Nothing to keep me from riding but it is annoying. Since I've had it, it will start and idle fine but after it gets warmed up, it won't idle unless you keep on the throttle. I've adjusted the idle speed with little or no cure. Could it be the jetting? Or something else? Anybody else have similar problems?
    stoney420's Avatar
    stoney420 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Bridgeport, NY
    363
    im not sure if i still have the problem cause i just got done cleanin my carb and etc but i was having the same problem with my 85 ytm200, after it got warm it would only idle for like 15 seconds or around there then it would slowly die out so i would appreciate help on this matter also
    Mar 2007
    Minnesota
    102
    I have a similar problem with my 84 YTM200. After she warms up real good it has a tendency to die after giving it the slightest bit of throttle. I have learned to avoid little touches of the throttle but instead just gun it.
    I have pinpointed the problem to be something electrical. I'm thinking the ignition coil. Once the coil heats up it does not fire as well as it did when it was cold. I see this all the time with outboard motors; they run fine until they get hot. Then they start to act up.
    Classical electrical problem.
    One thing to do is a resistance test on the coil. That will tell you if it is firing like it should.
    mark38090's Avatar
    mark38090 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Hawthorne, Florida
    354
    I had the same problem with my 85,, bought a carb kit and now it will idle, but not a smooth idle.
    1984 Honda TRX200
    1985 Yamaha 200ERN ( two of these now)
    1985 Honda 250SX
    1991 Suzuki LT230
    2003 Honda Rancher 350ES
    Jul 2004
    Blue Ridge Mountains
    141
    My Dad used to have the same problem on his YTM200EK back in the day, and my 85 DX does it also but only when it's hot out. In the winter, my 85 is fine. I always thought it was carb adjustment or maybe the pilot jet...? I never pursued it though since I ride mostly in the winter anyway. Could be electrical like brad says... seems to be a common issue with the YTM's no doubt.
    Sargon
    ** '85 Yama- 225DX (wheelie machine)
    ** '85 350X (current project)
    ** '86 TR200 FATCAT (Old Faithful)
    ** '91 KDX250 (The Green Machine)
    Mar 2007
    Minnesota
    102
    "My Dad used to have the same problem on his YTM200EK back in the day, and my 85 DX does it also but only when it's hot out. In the winter, my 85 is fine."
    Bingo.
    Sep 2005
    central Illinois
    651
    anybody know of a place to get a new coil? Yamaha dealer maybe? couldn't find anything on denniskirk, but that's where I got the lighting coil?
    Jul 2006
    Pennsylvania
    29
    Mine does the same thing.....idles fine until it warms up, then won't idle. The carb is clean as can be. I've adjusted every possible thing to no avail. Runs like a top otherwise. I just learned to live with it. The cure is probably something simple, I just havn't figured it out yet.
    Mar 2007
    Minnesota
    102
    Try the dealer for parts.
