Results 1 to 15 of 22
Thread: golf ball cannon???
    Sep 2005
    central Illinois
    651
    golf ball cannon???
    So since I work at a golf course part time, I have access to free golf balls, I usually find 6 or more a day on the course. Doesn't sound like alot but it adds up quick! My friend and I were contemplating what to do with the crappy ones and we had an idea similar to a potato gun, but for golf balls. Sounds like hours of fun to me Anybody done this before or have an idea of where to find plans to make something like this? I'm gonna start searching, so if anybody wants to throw out some ideas, lemme know!
    Sep 2005
    central Illinois
    651
    found a starting point, this gives me some ideas anyways...
    http://www.youtube.com/watch?v=Mg5knknqNTU
    I think I'm going to make something similar or set up where I can regulate propane into it so it will be quicker between launches
    Sep 2005
    Lipetsk, Russia
    2,824
    My friend makes potato guns all the time out of PVC piping and some fittings. He uses starting fluid as the propellant.
    I think a golf-ball cannon might work if you got a reasonably solid material to make sabots out of, maybe some foam or something...
    I'm back in the USSR...
    Columbia
    5,131
    Quote Originally Posted by RedRider_AK View Post
    He's got to be putting potatoes through trees!
    Sep 2005
    Lipetsk, Russia
    2,824
    He shot a wooden spear, no metal tip, through a 5 gallon jerry jug that was empty and not held down in any way, lets put it that way. That spear was haulin' some serious ass.
    Aug 2005
    Lockport, NY
    2,395
    Starting fluid, mad dangerous. I have had phenomenal success with AquaNet hairspray. Highly flammable. Works superb.
    As far as a golfball cannon it can be done for sure. I have done a fair share of pneumatic potato guns. To date the best was done with a 2'' dia. 4 foot long barrel. I used schedule 40 pvc. I used two 90 degree elbows. On one end i had a pvc tank 4'' diameter about 25'' long. One end had an endcap. The other end had a reducer down to 2". Inbetween tank and barrel i used a ball valve. I would charge the tank with 125 lbs. Then dump the valve. Worked out great!
    Columbia
    5,131
    Aquanet sure does the trick!
    Hairsprays the way to go.
    Sep 2005
    central Illinois
    651
    oh geez, what did I start? Ha ha, found a couple of links to give me some ideas...
    http://www.advancedspuds.com/golf.htm
    http://www.plans-kits.com/project2.html
    http://advancedspuds.proboards27.com/
    The second one sounds super dangerous but that equals amazing fun! But I couldn't get any of the pics to load. The last one looks like there are actually guys out there as passionate about making a otato fly as we are about trikes
    Jul 2006
    iowa
    451
    i've made a few potato guns, one is around 6' tall with about a 6" chamber and about 2-2.5" barrel (dont remember measurements exactly). for propelant i used a of clear coat and had a grill sparker built in the gun to ignite it.
    if you want something kinda cool to mess around with indoors, all you need is one of those long BBQ lighters, a medicine bottle, and a bic pen. take the pen apart so all you have is a plastic tube (your barrel). then make a hole in the bottom of the medacine bottle and in the lid. super glue the plastic tube into one hole, and the lighter into the other. fill the medacine bottle with an extremely small "puff" of something like from a can of axe deoderant. you can shoot stuff like paper wads and Q-tips out of it, and its actually pretty fun if your bored.
    Jan 2005
    Jones, Michigan
    1,821
    mine is/was for tennis balls or gold balls but you had to wrap duct tape around the golf balls for a tight fit.. We used 3 ft of 6inch diamter pvc pipe for the gas chamber and 3 ft of like 2 or 2 1/2 inch pvc for the barrel. Use the proper connectors, drill a small hole at the bottom for a lantern lighter, install the lighter, cram a tennis ball ( or duct taped golfball) pretty snug into the barrel all the way down almost to the gas chamber, unscrew the bottom of the gas chamber and spray starting fluid into it, put the cap on, point it away from you, hang on and flick the lighter. Mine would blow golf balls through 3/4 inch osb at about 50 yds if i still have it in the attic i'll post pics. Like john said though, I WILL NOT BE HELD RESPONSIBLE FOR WHATEVER YOU DO!
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Baltimore, MD
    6,088
    You can use a potato gun indoors if you wet a shoprag and stuff it down the barrel. It really scares your buddy when he is exiting the bathroom and you light off a potato gun with a wet shop rag just as he opens the door. Beware of flammable fumes though!
    Jan 2005
    Jones, Michigan
    1,821
    Quote Originally Posted by hondahaulic View Post
    you posted right before me
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    Jan 2005
    Jones, Michigan
    1,821
    for some added effects, if you use tennis balls soak them in gas first
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    Aug 2005
    Lockport, NY
    2,395
    lmfao, soaked in gas. Its time to build a gun. Kindled intrests!
    Columbia
    5,131
    Thats freakin awesome!!!!
    Time to go get in trouble!
