Will Tecate 4 axle work on a Tecate 3??
Just wondering if anyone out there knows if a Tecate 4 axle will work on a 86 Tecate 3? Thanks
The info I've gotten is that all those parts back there are different and wont work but never tried it first hand
Thanks Bill, thats what I thought also.
From post:
http://www.3wheelerworldforums.com/s...385#post456385
AS for the 86+87 you can use a tecate 4 axle.
I have been keep this under my hat for alittle while,after that ordeal with the decals I swore I'd never help this stite again.I give you 1 more chance.
there are 2 things you need to know.
first: you can only use the eliminator axles.the tecate 4 is shorter then the tecate 3.so a plus 4 is only going to be +2 or stock.
second: you must use a rad lock nut there is not enough threads for double nuts.
THANKS TRIZTUNES!!!!!!
Also from post: http://www.3wheelerworldforums.com/s...ght=400ex+axle
Look for an extended 400ex axle. I put a RPM Dominator axle in my tecate bearing carrier. I used a 350x brake disc hub and axle nut. I also modified an 84 T3 brake disc to work. You will need to space out your brake caliper if you do this.
86 T3
84 T3
86 KX250
//ArrowChat Integreation Code
