As soon as I turn the gas to on or reserve it just starts pouring out of the drain tube. I thought maybe a little piece of dirt might have gotten in the carb so i pulled it all apart and cleaned everything. Put it back together and it was ok. Took it for a ride, and as soon as I stopped it started doing it again. I took it apart 2 more times, trying to figure out what the problem is, but it wont stop. I just rebuilt the carb with all new parts, fuel filter, you name it. The float is fine I think, I dont see how it wouldn't be, it moves up and down freely and it's free of all debris.
Can someone tell me what is causing this???
When I had the carb apart, I took just the bottom half, and poured a little gas in it to see if it would run out the drain tube and it didn't, it just sat there until I unscrewed the drain screw and then it drained as normal. So it has to be something with the jets, float or something. I dont get it!!!! :evil: :evil: :evil: :evil:
