yamaha tri zinger help
Hey guys. On the yamaha yt 60 tri zinger can you run the plastic oil can empty and just mix the gas with pre mix in the tank? Is this trike oil injected? the plastic tank says motor oil on it but I am wondering if that is the oil injection tank. I see a pump of some sort that looks like it goes to the carb so i am afraid to just disconnect it for fear of dirt sucking in. Have any of you worked on one of these or know what I am talking about? Thanks for any help.
own:
1986 250R- ported polished, carb mods, Esr atc-5 pipe and silencer
1986 250R- mild porting, carb mods (Clean!)
1985 350X- all stock (super clean!!)
1985 350x- desert project in the works
1986 250sx- Mostly stock
1985 200x- (pretty clean mostly stock)
1985 Yamaha tri zinger 60
