Thread: !978 Honda Express drain/fill plug
    Albert Lea, MN
    38
    My brother owns a '78 express NC50 and need to know where the oil drain and fill plug is. the chain case is soked in oil so I think I need to add some oil to it. It's the case that the chain that runs to the rear wheel is in. Any help would be greatly appreciated.
    Thanks,
    Dan
    Jan 2005
    RI
    2,530
    could that be chain oil?
    Look up a parts fiche if possible...maybe you can find it then
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jan 2005
    RI
    2,530
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Baltimore, MD
    6,088
    If I remember right and it's been a long while, one of the bolts on the bottom of the chain case is used as the drain plug. If I remember correctly, the cover is shaped differently at that bolt to help it drain. Check the bolts along the bottom of the chain cover and see if I have remembered right.
    Albert Lea, MN
    38
    I will check into the bolt on the bottom and let you know what turns out.
    Thank you for all your quick response,
    Dan
