Results 1 to 15 of 15
Thread: The piece that just fell out. 85 250 es
    Jun 2006
    Niagara+SouthRiver ONT.
    132
    Exclamation The piece that just fell out. 85 250 es
    Taking my motor out was a whoor because the bottom motor mount bolt was fn froze big time.
    When I tipped the bike working on the fn bolt that was stuck this little gem fell out on the floor.
    It looks like part #5 from the shift drum on bikebandit.com, but I am stuck ....
    Any help would be great.
    I am going tomorrow for my shift fork and gasket set, and flywheel puller so I need to be prepared for assembly.
    Cheers
    85 Honda Big Red 250 es
    85 BMW 318
    67 Chevy C10 383 M21
    Jun 2006
    132
    5: Discontinued
    62679-001
    $2.98
    85 BMW 318
    Jun 2006
    132
    not sure how it could fall out but who knows. The motor got stuck in Rev. from a worn Rev R shift fork and the bearing on the bottom of the shift drum is angled with wear on the letter stamp.
    Columbiaville, MI.
    1,508
    I ain't 100% sure ,it's been awile since I was into that motor but I think this is where your piece goes.. Like I said not 100% sure but I think so.. I hope this helps!!
    MDR Racing
    LONG LIVE SANCHEZ RACING
    Jun 2006
    132
    man thanks. That is a hard shot to see it but I'll check it out.
    85 BMW 318
    Jun 2006
    132
    good call it looks like a fit and when looking closer I found another broke part. Thanks man. Now I have to order this part too and pick it all up. Looks like the Big footed *Edited**Edited**Edited**Edited**Edited**Edited**E dited* that smashed it in Rev busted the whole *Edited**Edited**Edited**Edited* up. Dam CSI eveidence now man. Never let anybody ride your *Edited**Edited**Edited**Edited* man.
    I have the motor in the garage now that has this part. I'm off to rip off the side cover and see what I have
    Thanks again for that little direction.
    85 BMW 318
    Jun 2006
    132
    here is the part I found on the cover I over looked earlier. But I did find a worn Shift Fork and Bearing on the mission
    We are close now what a battle. Just have to get the part now.
    So far I have
    Gaskets $65
    Shift Fork $60
    Flywheel puller $20
    Now this part and that should do it
    Just might pass 250 es 101
    Yep, all the automatics get ed. The left sidecase is the first gasket that gets unsealed on the SX and ES/Red. The one pin to the lower right of your shift drum is the pin that snaps or comes loose. Be sure to check it out.
    I have'nt owned an ES but the SX has a few metal shouldered collars all very similar to the one you found.
    How did you yank the motor?, I hope you didn't pull the output shaft with the allen head bolts. It's best to pull off the rubber boot and slide the driveshaft back. But, if you did yank the output - I know how to get it back in correctly...
    Steve
    hey, that's what happens when someone runs into a tree or whatever with the shifter.
    one cylinder is not enough!!
    Sep 2006
    NEWFOUNDLAND
    53
    i had my old 200m one time and i went over a fence so i could tear up the ball field the shifter got caught in the mesh fence and wrapped it right around the foot peg
    didnt hurt nuti only the shifter tho :P
    Feb 2007
    flordia
    34
    yep my old sx did that.i tried to clear a double and didnt make it . fliped like crazy and after that i had to really yeank on it hard to get it to shift until i got a new one
    Columbiaville, MI.
    1,508
    Cool glad to hear you know what the part is , Let me know if CSI Muddogs can help you out anymore!! With you and Relapse I have my hands full !!! LOL
    MDR Racing
    Jun 2006
    132
    Well I just took the whole part off the other motor so I good to go.
    That is from letting a BIG FOOT Moron ride your *Edited**Edited**Edited**Edited* that doesn't give two *Edited**Edited**Edited**Edited**Edited**Edited**E dited* *Edited**Edited**Edited**Edited* fucks about your *Edited**Edited**Edited**Edited**Edited**Edited**E dited* *Edited**Edited**Edited**Edited* *Edited**Edited**Edited**Edited**Edited**Edited**E dited* *Edited**Edited**Edited**Edited* man.
    85 BMW 318
    Jun 2006
    132
    Get my parts on Saturday, have the crank switched over and assemble time is near now.
    Buddy is coming by on Friday to buy my other motor so I'll have to let em know the Lever is toast too.
    He only wants the block anyways...
    Jun 2006
    132
    I got the motor in and out down to a science now. The sx motor is in there now and the OEM es motor is the one all apart on the bench.
    They are the same by the way except the black paint.
    The SX model is the other parts
