Results 1 to 11 of 11
Thread: What octane?
    Apr 2003
    15
    What octane?
    The guy I purchased my 350X off of (my first one) suggested that I run 87 or 89 octane but NOT 92/93. What do the experts suggest? It is a stock engine.
    Jun 2002
    Mississippi
    2,552
    octaone is just a raing number to show fuel ability to resist detonation. to make the most power you shoulds run the lowest octane gas you can but not detonate. a common mistake is thinking race gas will make you run faster. it will actually slow you down if your compression is low.
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Detroit, MI
    837
    87 is safe with your bike, but often times the higher the octane # the cooler your machine will run. I would stay with 87 or 89 if I were you. 92-93 is safe but not really needed. I've never seen a 350x overheat, even idling in 100 degree heat, with a lot of humidity, and running on 86 octane gas.
    1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
    Nov 2002
    1,189
    someone in the dunes had a suzuki twin 600 cc streetbike motor in their quad running 92 octane. my uncle was able to keep up with a 400ex, with ease. my uncle was running 87. the guy was having problems with tuing all day. went to 87 octane, and was fine. the 92 detonated so late that he had to advance the timing in order for it to run correcly. i say, why spend extra for what you don't need?
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Fresno Ca
    2,695
    use some of the leaded airplane fuel that stuff works great
    Rittman, Ohio
    6,276
    If your motor doesnt knock or ping, your octane is high enough. Anything beyond what is needed will do absolutely nothing for you, nor will it in any way harm you. Its simply wasting money. Id start with 87, and see how it runs, and then go higher if needed. Remember, in the mid 80's when these came out, unleaded gas was 87 octane, "regular" was 89 and had lead in it, and premium was only 91 octane. 93 octane wasnt even readily available at the pumps at that time, so I have to laugh at those who insist you need it for a stock motor. Of course if youve done anything to boost compression, youll probably need to boost octane.
    Aug 2002
    332
    The only bad thing about running lower octane fuel is that the fuel additives like detergents are better when you buy a higher octane fuel. Actually, a good portion of the price difference is the fuel additive package that is mixed into the gasoline. If you get on the major oil company websites you should be able to find out which low octane fuel brand has the best detergents and use that brand. It's like comparring oranges to tangerines...they are both good and you'd enjoy either one of them, so don't get your panties into a huge bunch if you have to go with one or the other for some reason. My $0.02.
    Joel Morris
    Purdue University Graduate Student
    Mechanical Engineering Technology
    1985 ATC70
    web.ics.purdue.edu/~jsmorris
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    The factory 1985 350s manual states on page 11
    Any automotive gasoline with a pump octane number of 86 or higher may be used. If "knocking" or Pinging" occurs, try a different brand of gasoline or a higher octane grade.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Mar 2003
    Barnesville,Ohio
    2,298
    I use 87 in my 350X and it works fine.
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Apr 2003
    15
    I understand now. THANKS!
    Bill X_R is offline Bill "The Finger" XR oo|oo Arm chair racerJust too addicted
    Feb 2003
    Cincinnati, OH
    672
    I Run Jet fuel in my lawn mower and I can get the grass done in 1/2 the time!!!!
